Notices
2005-2009 Mustang S197 Discussion & News
Power seat switch not going forward. $5 fix
Old 4/1/19, 09:23 AM
wanted33's Avatar
I know there had been other threads about the pitiful power seat switches in the S-197's. But it isn't just the Mustangs as these switches were/are used across the Ford line of cars. After searching the forum I didn't see this information. The power seat in my '06 would move every way except forward, so I knew it wasn't the motor. After some searching I found a suggestion to try this before spending the almost $150 for a new switch. So, I thought I would share it as mine is working fine now.
First stop by your local Wally World, and pick up a can of CRC qdc electronics cleaner spray for $4.77 if you don't have any. Now we remove the seat back lever. It's sounds easy, but that **** little clip is a pain. Then there is a philips head screw at the back of the side panel you need to remove. There are 3 clips on the panel, 1 at the back, 1 in the middle, and 1 in the front. I never got the one at the front to pop loose, the clip is part of the lumbar switch holder so I just gave up. But, I was able to swing the back of the side panel out enough to get in there. Now comes the removal of the power seat switch itself. Here's it becomes a bit aggravating as the switch is held buy 4 little push in clips, 2 top, 2 bottom. The trick is to get 2 partially un-clipped, and keep them from attaching again while you're getting the other 2 un-clipped. The use of my go to "deleted expletive" helped a bit, and I finally got the switch out of the holder. The plug is held in by 1 clip on the bottom side.
The switch cover can be removed using a thin blade tool, knife, etc. Do not man handle this cover, you don't want to screw up the moving parts under that cover. Make sure the 3 moving tabs are centered before reattaching the cover. You will see where the contacts go into the center of the switch under the three moving tabs. Take the contact spray, and spray copious into the little slits where the contact are bent into the switch itself. Shake out the excess liquid, give a blow to dry the residue, hook the switch back up, and you should be back in the groove again. Hopefully you just saved yourself quite a bit of money. Good luck
BTW, as far as I could tell the same switch was used by Ford in the 2005 through 2013 years of the Mustang.
Jim
wanted33 is offline
VGMStudios (4/10/19)
Xenomorph
Warranty and Service Issues
2/26/19 05:31 AM
cinque35
Want To Buy
10/5/11 01:52 PM
Zastava_101
12/4/09 05:30 PM
Moosetang
4/29/08 04:13 PM
KKGray
1/25/06 08:00 PM
Quick Reply: Power seat switch not going forward. $5 fix
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
