passing with no cats help!!!
Old 12/26/11, 04:12 PM
sinisterbullitt's Avatar
I actually do inspections out of Houston.
Old 12/27/11, 06:52 AM
KdF
KdF's Avatar
I was under the Impression you could only get a Inspection in the County your vehicle is regestered in.
Am I wrong?
Old 12/27/11, 09:29 AM
No not at all. But if he is in Harris county more often than not it shouldn't be a problem. I have a friend that works out of Louisiana but doesn't live there. He was getting stopped often enough for not having a valid inspection sticker that he went ahead and got one in Louisiana. So far he hasn't had any problems and I've actually seen other people do it to
Old 1/3/12, 03:43 AM
Bucko's Avatar
It's a federal law to have to run cats on the street. Even if your local county or state laws allow you to "get away" without them, a police officer can stop you and fine you 30K. This happened to my son, who insisted on running without the cats on his SRT4 Dodge. It cost him lawyer fees to get out of the fine, but that was still $2500.00.
I'd run some good flow cats with the system.
Old 1/3/12, 05:14 AM
cpotts13's Avatar
You guys are making me seriously nervous about putting an off road h pipe on, Wich I happen to be doing today...
Old 1/3/12, 08:17 AM
Scruffy281's Avatar
Then don't do it.
Old 1/3/12, 11:33 AM
cpotts13's Avatar
Originally Posted by Scruffy281
Then don't do it.
Its worth the risk, ill get some high flow cats later on.
Old 1/4/12, 02:28 PM
mdelao's Avatar
I was thinking to remove them too, did the check engine light turned on?
Old 1/4/12, 02:36 PM
Bear Eats King...
Bear ****s Bone
texastboneking's Avatar
The only cats I own have names
Old 1/4/12, 04:26 PM
cpotts13's Avatar
For what ever reason mine hasn't came one yet.
Old 1/4/12, 04:34 PM
Bear Eats King...
Bear ****s Bone
There is a trick to keep the light off. Costs about 20 bucks
Old 1/4/12, 05:34 PM
cpotts13's Avatar
wish i would have known that before i spent more on the dang eliminators. But i havent put them on yet and the engine light hasnt came on either
Old 1/4/12, 05:56 PM
Bear Eats King...
Bear ****s Bone
It takes a couple drive cycles for the light to set.
Old 1/4/12, 06:05 PM
Calgon Take Me Away!
lalayla's Avatar
I don't even have cats with names.
Old 1/4/12, 06:34 PM
A Man Just Needs Some....
AlsCobra's Avatar
You didnt name your cat?
Old 1/4/12, 06:39 PM
Bear Eats King...
Bear ****s Bone
You should have a cat... or else I'm mistaken.
Old 1/4/12, 06:48 PM
mdelao's Avatar
Did you feel so much difference In the power and noise?
Old 1/4/12, 06:52 PM
cpotts13's Avatar
I little better throttle response, but it sounds night and day.
Old 1/4/12, 07:08 PM
lalayla's Avatar
Killa ran away.
Old 1/4/12, 07:11 PM
  #40
Bear Eats King...
Bear ****s Bone
Killa ran away.
You didn't leash that thing?
Quick Reply: passing with no cats help!!!
