Idling Problem / Constant Repairs - 05’ 4.0L V6
Old Jan 18, 2018 | 07:37 PM
Wolf Mxbee's Avatar
I have recently got an oil change and replaced the following:
- E3 Spark Plugs
- Motorcraft Fuel Filter
- Air Filter
- Spark Plug Wires
- Coil
- EGR Valve
- Fuel Pressure Sensor
And even bought some mass air flow cleaner and cleaned my MAF sensor and the car still idles very rough and I have the following codes:
- P0305 Cylinder 5 Misfire
- P0108 Barometric Sensor Circuit High Input
- P0171 Fuel System Too Lean (Cylinder Bank 1)
- P0174 Fuel System Too Lean (Cylinder Bank 2)
- P0182 Fuel Temperature Sensor A Curcuit Low Input
- P0193 Fuel Rail Pressure Sensor High Input
- P0300 Random Misfire
Old Jan 19, 2018 | 05:57 AM
wow thats a heck of a list.
Old Jan 19, 2018 | 09:25 AM
Wolf Mxbee's Avatar
Yep, it sucks, it said Bank 1 and bank 2 and when I use to own my 06’ Passat, Bank 1 and bank 2 usually referred to O2 sensor so I ordered some and thy should be here tomorrow
Old Jan 23, 2018 | 09:49 AM
Lime GT's Avatar
Were these codes there before you did all this work? If so Clear all codes and start again. Also recheck and make sure you reconnected any sensor connectors you removed to do your repairs. List the codes here again.
Old Jan 23, 2018 | 10:12 AM
Joeywhat's Avatar
The code for the O2 sensors doesn't mean they're bad, it means they're reading a bad condition... Replacing them won't do anything.
Old Jan 26, 2018 | 03:23 PM
Wolf Mxbee's Avatar
I cleared the codes and my car ran somewhat better but then the codes came back up and the car still idles weird at times but now its not constant
Old Jan 28, 2018 | 08:38 PM
Lime GT's Avatar
What codes came back?
Old Jan 30, 2018 | 06:31 PM
Wolf Mxbee's Avatar
So far no codes have came up, I have bought a cold air and was running okay but sometimes ran rough such as idle and misfire from running too Lean, now I put my stock one back on today and my car is a little better, went from 12-13 to 15 mpg but the car idles at park under the 0 and when I go to turn my car off, the gauge needle tries to force itself down to it ticks and shakes 3 times
Old Jan 30, 2018 | 06:51 PM
SpectreH's Avatar
Have you checked for vacuum leaks?
Old Jan 30, 2018 | 07:24 PM
Wolf Mxbee's Avatar
Actually that’s what I was going to ask earlier if anyone knew what hoses would lead to and cause a car to idle? And where are the most common places to check, btw when I have my intake off, my throttle body was relatively clean so that’s one issue marked off and I bought two O2 sensor replacements and installed a couple days ago and it helped the issue but still idles rough
Old Jan 31, 2018 | 11:58 PM
Lime GT's Avatar
I don't know much about the v6 but you might want to try these two tests. Seems like a couple of common vacuum problems with the 4.0l.
http://troubleshootmyvehicle.com/for...d-P0174-page-3
page 1 and 2 also have some good info.
Old Feb 1, 2018 | 01:05 AM
Wolf Mxbee's Avatar
I checked out the link and will do that tomorrow when my car cools down and may possibly put my old spark plugs back in because I got the E3 sparks but people talked about the gap concern could cause a misfire but I doubt it with the e3 because people on here have had goodluck with them and plus my car was running amazing when I installed them then a week down the road everything started to go wrong
Old Feb 1, 2018 | 07:38 AM
Wolf Mxbee's Avatar
Update, my car was getting 13ish to the gallon wit the cold air and now it went down to 11 to the gallon with the stock one back on. yesterday I was driving and it was hot outside, my car every time I pushed down the pedal, my car would shake and feel very sluggish like there is a **** ton of fuel being dumped as if my car is drunk or a heavy drinker but when I go full foot down to make the revs higher, then it balances it self out again and then it goes back to that weird feeling but right now it’s cold (6:37 Am) and no problems, I mean a few little idles here and there but runs better...?
Old Feb 1, 2018 | 07:43 PM
Wolf Mxbee's Avatar
So my idle goes below the very first tick or dash on the gauge... well okay basically when the car is off, where the needle sits at, when running and warmed up, the cars needle is below the position when off and it bounces around there, I heard that a battery and alternator could cause a 05 mustang 4.0 to idle very bad? Is this true
Old Feb 2, 2018 | 05:48 AM
no after market tune in there that you might not know about?
Old Feb 2, 2018 | 06:28 AM
Wolf Mxbee's Avatar
The car has jba headers, and had a sct badge on the dash but I took it off and I also disconnected my negative and my whole battery sometimes to clear the engine light and people said if it did have a tune then that would erase it
Old Feb 2, 2018 | 07:10 AM
SpectreH's Avatar
Disconnecting the battery does not erase a tune.
Old Feb 2, 2018 | 07:32 AM
Wolf Mxbee's Avatar
Well I mean I doubt it would be a tune issue if it had one or not because it drove mint for the first month and two I had it
Old Feb 2, 2018 | 07:43 AM
Bert's Avatar
Originally Posted by Wolf Mxbee
. . . I have bought a cold air and was running okay but sometimes ran rough such as idle and misfire from running too Lean, . . .
It sounds like there could be a lot of things going on here. if you are making modifications without making the needed adjustments to the tune that are needed for those modifications, then that might explain a lot of the problems.
It will be very hard for use to help you sort this out because it sounds like there might be a lot more to this story.
Old Feb 2, 2018 | 07:49 AM
Wolf Mxbee's Avatar
I put my stock one back on, and it still had the problems before the cold air, I decided to put 87 vs 89 which I usually get but just wanna test it because when I put a different octane my car feels weird right away with the mixture and then balances it self out
