-   2005-2009 Mustang (https://themustangsource.com/forums/f637/)
-   -   Help with programming OEM remotes (https://themustangsource.com/forums/f637/help-programming-oem-remotes-466081/)
hotairgypsy Mar 29, 2008 12:48 AM
I need some help from some higher end technicians or troubleshooters. let me give you some background too my lil project. I am attempting to install the factory OEM Active alarm system from an 07 GT into my 05 GT. I have the smart junction box installed along with the antenna. I installed the overhead with the motion and incline sensor and the hood switch tonight.
Here is my problem...I CANNOT GET THE REMOTES PROGRAMMED!!!! arg!!!! I am sooooo close to being sucessful. If i hit the lock switch before exiting the car it will arm the system. If i come back to the car and unlock the car by key, unlock the trunk by key, or reach in the window and pop open the hood it will set off the alarm. I have everything working but the remotes. I cannot get into programming mode.
YES I KNOW ABOUT THE TURN THE KEY ON AND OFF 8 TIMES AND WATCH FOR THE CAR TO UNLOCK AND LOCK TO SHOW YOU ARE IN PROGRAMMING MODE.
It is not working. here are the instructions
From the Owner's Guide:
How to reprogram your remote entry transmitters
You must have all remote entry transmitters (maximum of six)
available before beginning this procedure.
Note: Ensure the brake pedal is not
depressed during this sequence.
To reprogram the remote entry
transmitters:
1. Ensure the vehicle is
electronically unlocked.
2. Put the key in the ignition.
3. Cycle eight times rapidly (within
10 seconds) between the 1
(OFF/LOCK) position and 3 (ON).
Note: The eighth turn must end in the 3 (ON) position. The doors will
lock, then unlock, to confirm that the programming mode has been
activated.
4. Within 20 seconds press any button on the remote entry transmitter.
Note: If more than 20 seconds have passed you will need to start the
procedure over again. The doors will lock, then unlock, to confirm that
this remote entry transmitter has been programmed.
5. Repeat Step 4 to program each additional remote entry transmitter.
6. Turn the ignition to the 1 (OFF/LOCK) position after you have
finished programming all of the remote entry transmitters. Note: After
20 seconds, you will automatically exit the programming mode. The
doors will lock, then unlock, to confirm that the programming mode has
been exited.
I do not have a remote from the 07 the smark junction box came out of. How am I going to simulate step one without an original remote?
I have tried using the button on the door and lock then unlock then turn the key 8 times but didnt work....I NEED SOME MORE IDEAS!!!
I think this is all I lack and I will have succeeded.
