Fuel Issue
Hello,
I am having issues with my 2006 V6 4.0 mustang. Standard stock. It stopped running on me, thought it may be a filter issue so i replaced that. After trying to start the vehicle with now success i removed the new fuel filter and green/yellow fuel came spewing out. If this is a common issue i would like to know. In the process of pressure testing the fuel system to see if it may be a fuel pump issue as to why it won't start. Will turn over but not run, unless given throttle and even then only runs for 2-3 second. Any advice to a newbie? Thanks B |
Originally Posted by Branden Cardenas
(Post 6991196)
Hello,
I am having issues with my 2006 V6 4.0 mustang. Standard stock. It stopped running on me, thought it may be a filter issue so i replaced that. After trying to start the vehicle with now success i removed the new fuel filter and green/yellow fuel came spewing out. If this is a common issue i would like to know. https://cimg3.ibsrv.net/gimg/themust...a18ba7649.jpeg In the process of pressure testing the fuel system to see if it may be a fuel pump issue as to why it won't start. Will turn over but not run, unless given throttle and even then only runs for 2-3 second. Any advice to a newbie? Thanks B https://cimg5.ibsrv.net/gimg/themust...7b6897e9e.jpeg |
you might want to check your fuel injectors
Did you reset the fuel cut off switch?? There's a hole in the drivers side kicker panel. Stick your finger in there and push the button down.
