Ford Service Manual DVD doesn't work ??
2 Attachment(s)
I downloaded the 2005-2006 Ford Service Manual DVD & 2007-2008 Ford Service Manual DVD from the http://www.fordcds.com/ site via their torrent files. After burning the DVD and installing it, I get the following message (the volume has expired ... discard disk) when I run the application:
Attachment 20175 Any Idea ?? |
I am downloading it now. Someone let me know if I need to continue.
I think you have to change the date on your computer
Originally Posted by Galaxie
(Post 850921)
Same thing happened to me, Ill try the date thing tonight
I have the DVD, and the volume printed on the disc says November 2006. If I change my computer date back 4 months, it works.
change the date 2 years back and it will work
Ok. Here is the deal. Your mileage may very. If I were to download the 2007-2008 Ford Service Manual DVD.iso, here is how I would do it. This method is garanteed to work...allegedly. It has a number of steps simplify it to suit your taste.
(1) Download and install Vmware Server (or use Vmware workstation if you already have it) (2) Create a virtual machine for Windows XP (3) Set the virtual bios date to 7/23/2006 (4) Disconnect the virtual ethernet adapter (5) connect the 2007 FSM DVD.iso to your virtual machine (6) log on to your virtual machine and access the 2007 FSM DVD and run setup.exe to install the product. (7) Use and enjoy the product. |
Originally Posted by Embalmer
(Post 850944)
Originally Posted by MontrealStang
(Post 850990)
Maybe I need to back the date BEFORE installing it... will try it tonight:dunno:
If you use virtual server software (vmware), you can do all of this in a virtual environment and not have to worry about the side-effects of turning back the clock on your other applications. That is why vmware is good for these type of things. It also creates a sandbox area for untrusted downloaded software and prevents any unknown viruses and malware from infecting the rest of your machine. |
i have the August 2006 volume which expired on October 2006..
i can load it up anytime by setting the system clock back to September 2006.. i don't really have much use for the DVD as i saved every PDF in the workshop manual individually, so the interface is of little to no use anymore :) |
I have the 05-06 and 07 DVD's. The one needs to be set back to before august 05 and the other 06. I changed the date before installing them. But I changed the date back after it was installed, and I just change it before viewing them.
I changed the date AFTER installing it tonight and it worked. 07 Version, set it to Oct. 06.
Tried it this morning ... it worked. I guess I hadn't back the date enough yesterday
Thanks guys !:metal: |
Glad you got it working. I have to back mine up to Jan 06 for it to work.
What's everyone's thoughts on getting a new one let's say in a couple of years? I mean for $25 even once a year. I have an 06 GT, so what could be updated? TSBs? But those are online anyway. Would it be worth it? |
I've been trying to download this for a while and have been unsuccessful.
Originally Posted by Deric
(Post 852315)
I downloaded it and it's over 5GB. Are you guys using dual layer DVDs to burn the image? I only have single layer. I'm I gonna have to go out and purchase some DL ones?
Originally Posted by bigkbull
(Post 852352)
(Post 852352)
