Windshield washer sprayer help!
I lust for a M24
They should both be driven by the same pump, so either there's dirt in the line (unlikely) or there's something clogging the nozzle. This normally happens if you're not careful waxing and a little wax gets on the sprayer and hardens.
Also, do you use windshield washer fluid or water like some in southern climates do?
Legacy TMS Member Eu Edition
Had one of mine go out... Of what I gathered they just disconnected after the pump and at the nozzle, and hooked a compressor up to the line. Just blew it through. Needle opened the nozzle itself, so I'm happy again
Originally Posted by benjyc32
How come you can't unplug your wiper fluid tube without removing the cowl?
Originally Posted by 2002VertGT
On my car the tube runs inside the drivers. Fender into the firewall...the sprayers are on the cowl...
That sounds like a terrible design...
If u still have the 01 vert yours should be the same as mine...mines only a year newer
Are you sure you can't just access it by pulling the felt pad off the roof of the hood? I'll have to take a look at mine when I get home... Now I'm curious.
Originally Posted by 05GT-O.C.D.
You still haven't fixed this yet? Did you stick a toothpick in there to check to see that the nozzles aren't simply clogged as is very common?
I actually just stuck a toothpick in it and nothing still...that and either I need more fluid or a new motor cause the drivers side is barely working...
