-   1994-2004 V-8 (https://themustangsource.com/forums/f636/)
-   -   radio size question (https://themustangsource.com/forums/f636/radio-size-question-398411/)
89rustang Jan 13, 2005 07:50 PM
i have a quick question. i had a 2000 mustang that had a single din radio with a seperate single din cd player or pocket. i am in the market for another mustang but i want the one with a double din radio, does anyone know what year between 2000 and 2004 they switched the radios? thanks!!!!!!!!
IIGood Jan 13, 2005 08:10 PM
2001, actually. Heh.
If you want the stock setup, you're probably gonna need to replace the whole HVAC tower in the middle there. I know what you speak of, as I have a '99 and a '03.
89rustang Jan 13, 2005 08:21 PM
i dont care to keep the stock setup the reason i want it to have a double din is to put in a kenwood excelon 6.5 inch screen dvd/cd and navigation. i work in a custom car audio shop and have done several of these and they fit like a glove and look awesome.
89rustang Jan 13, 2005 08:22 PM
so, you say 01 and newer will have that dash. so i need to shop for an 01
jgsmuzzy Jan 14, 2005 01:41 AM
Jason, as Frank said, you can pick up the tower parts for the dash for about $200. to remove, you have to remove the radio and CD player, remove the screw that holds the supporting bracket (down by the amp) and PULL HARD! it pops out. Simply replace with a 2001-4 piece and the job is done! (I cannot foresee a problem)
