2nd Gear Resistance / Mild Grind
Old May 23, 2012 | 07:18 AM
Chubbs88's Avatar
Had an all around bad day the other day... Hardcore 2nd Gear Miss Shift while racing a Z28... And then later in the day, I burned out my clutch while doing 2nd gear donuts. My 02' GT still drives... But the clutch is definitely shot. Now, there are many times when I try and put it into second gear... I can feel mild grinding. I'd like to chalk it up to being a bad clutch.... But 1st and reverse gear do not grind. Any thoughts? Is it time for a new transmission? New gears? Or will the New clutch possible solve my problem?
Old May 23, 2012 | 02:24 PM
Tommy d's Avatar
I would start off with a clutch Im all most positive that will fix 2nd gear problem
Old May 23, 2012 | 03:00 PM
Dbranham's Avatar
Do you notice the grinding to second more or less while going from 1st to second or while down gearing from 3rd.
Old May 23, 2012 | 05:08 PM
skunk21's Avatar
I agree with Tommy d start with the clutch ( you need one anyways) a worn clutch is going to make getting it into gear hard. There is a chance you hurt the syncro/gear but only slightly if haven't done this many times , my advice if you are going to row the gears hard get an after market shifter ( 1st choice MGW, 2nd choice Steeda ) more positive shifts than the stocker and adjustable shift stops which the stock shifter doesn't have.
you can also take a quick look in the "fox section" in our tech articles there is a clutch cable "how to" and the proper way to adjust the clutch, this works on your year also.
Old May 23, 2012 | 05:39 PM
1999Pony's Avatar
Change the clutch, if you are positive its bad. If it keeps grinding/being hard to shift, then next step is a clutch cable. If you havent replaced it in a while its probably stretched.
Old May 25, 2012 | 07:43 PM
cowboy's Avatar
Cars have bad 2nd and 3rd syncros you make it sound like you were beating on it so I wouldn't be surprised if you toasted them but start with the clutch. Also put your you're under the pedal and pull up to see if you get a click of the adjuster first.
Old May 26, 2012 | 01:02 AM
shaunrc's Avatar
If it were your clutch you would have gear clash in every gear being just second and third or whatever it is just a synchro
Old May 31, 2012 | 09:16 AM
Chubbs88's Avatar
Thanks all! The clutch should be replaced by tomorrow... So I will find out then. I will post the results so people with similar issues may be able to put their minds at ease.
Old Jun 5, 2012 | 03:30 PM
Chubbs88's Avatar
Clutch solved the problem. Thanks all!
Old Jun 5, 2012 | 04:33 PM
skunk21's Avatar
Awesome
Rando
Aug 25, 2021 11:12 AM
NC14GT
Sep 27, 2015 05:35 PM
y5e06
Sep 21, 2015 08:05 AM
samjluck
Sep 17, 2015 10:24 PM
Sep 10, 2015 12:44 PM
