Nitrous
Could I run a 75 shot of nitrous even tho I have 4.10 gears? And stock rear end?
- what fuel pump do I need? -and what size injectors? |
Nvm I'm crossed between turbo or nitrous think ill go down the turbo direction
But what fuel pump should I upgrade to? And what size injectors
255 lph pump and 42# injectors
Could I run that fuel pump and injectors now? Just set a tune for it?
And for the fuel pump 255 lph that's what I ask for I don't understand
No you can't run them now they would over fuel the engine even with a tune. The pump is 255 liters per hour. The stock pump only flows 88 lph
I think I heard about installing the focus fuel pump
Explain how your suppose to know which fuel pump to use on certain applications ?
If I go with h/c/I swap would I need a bigger fuel pump if so what one need specific brand type size etc
