how to get the 3.8L to sound better???
Originally Posted by fdjizm
Install cylinders 7 & 8.
Idk, flomasters I guess. Pypes makes a good true dual exhaust kit, Mac does As well. If you are going dual, the PLEASE get the gt bumper, or the Mac "dumps" after the axle.
Originally Posted by Dbranham
I seen a clip on YouTube with a v6 new edge with cherry bomb exhaust and it sounded amazing
Originally Posted by cpotts13
IMHO the ugliest thing about the new edge v6's are the exhaust tips. So if your going to make it sound good make the tips look good as well. Or just replace the old muffler with one of your choosing and put turn downs before or after the axle.
Get long tube headers! I have LTs, o/r h, slp on my 04. I'll admit slp does get raspy but I like it! Whatever you go with though get LTs. They will give it a bit deeper tone and better flow!
im going to order som Mac chrome LT headers and an off road Mac h-pipe. this will fit in my v6 no problems right ? the h-pipe takes place of the stock y pipe ? still learning exhaust stuff
Originally Posted by PonyBoy956
where did u buy ur slp's from
Also couple other things you'll want to know that nobody told me when I did mine. O2 extensions go on all 4 and you'll have to cut little tabs off of the stock one on the front sensors for it to connect no big deal. Secondly the back set which will be blue, read the air after the cats with no cats these aren needed but to keep your check engine light off you use MIL eliminators on that set only. The plug in ones are a little more but way easier than splicing into it. Just make sure you get the frog green ones hooked back up those control your air/fuel ratio I ran around without mine for awhile because I was new and didn't know lol. Hope this helps!
