Replacing Side Mirrors
Old Nov 28, 2007 | 09:52 AM
Budders's Avatar
Well the shiny plastic that has pretended to be a mirror for the last year is about to be replaced by a new mirror assembly.
I'm not sure how to go about replacing the mirror assembly, and since the internet knows everything I hoped that someone here would know what to do!
any knowledge is appreciated
thanks
Old Nov 28, 2007 | 10:15 AM
WaltM's Avatar
Sorry, I dont know how to do it. But I'd like to know what you are replacing the mirrors with?
Old Nov 28, 2007 | 11:14 AM
x21's Avatar
x21
For the Fox- it has been a while since I replaced my passenger side mirror. It was a power mirror at that too. All I recall doing was removing the little trangle piece on the inside of the door, then there are 2-3 nuts that hold the mirror assembly in. After you undo those, the assembly should just wiggle out (unless you had a power mirror, then you would also disconnect the wiring too). Hope that helps. And that is for the whole assembly, not just the part the mirror itself is attached to.
Old Nov 28, 2007 | 12:16 PM
WaltM's Avatar
Good to know. My Fox mirrors are beat.
Old Nov 28, 2007 | 04:56 PM
jacostang's Avatar
As above but the connector does not reach when you pull the mirror and most of the time you have to remove the door panel to access the plug...
Old Nov 28, 2007 | 08:44 PM
^+1.
Old Nov 28, 2007 | 08:57 PM
GT5088's Avatar
i did it on mine...its not bad at all, and I'm not that mechanically inclined.
HizliBullet
GT350
14
Nov 14, 2015 08:59 AM
MrSylphie
Aug 18, 2015 08:40 PM
poldrv
Aug 18, 2015 06:42 AM
