-   Fox Mustangs (https://themustangsource.com/forums/f634/)
-   -   Hard starting when warm (https://themustangsource.com/forums/f634/hard-starting-when-warm-546686/)
Darter1585 3/25/19 11:11 AM
I’m running a GT40P motor with an Edelbrock 650 CFM Performance Series carb in my 84 LX. After it warms up, if I shut it off then restart within the first 5-10 minutes, it fires immediately. If I wait more the 10-15 minutes it’s hard to start (flooded?). I put a kit in it to no avail but here’s a potential problem: when I tried to screw in the new seat it wouldn’t go in. I fought it for a while then gave up and reinstalled the old seat. It would be just my luck that the problem all along was a bad seat. Any thoughts?
Inkfreak1976 8/15/21 10:25 PM
old post but if it is flooded then i
the choke is stuck...
houtex 8/16/21 09:13 AM
Well, since we're here: Carbs boiled maybe. Sounds heat related for sure. Too much heat and poof, no fuel in the carbs, no start for a bit.
Just a guess, based on a similar situation with my motorcycle. I'm probably wrong. :unsure:
Also, welcome to the forums! :wave:
