800 hp???
Old Dec 31, 2010 | 03:50 PM
FordFan87's Avatar
800 hp???
I am looking to redo the motor in my 87 gt! I am looking to produce around 800 rwhp! I plan on buying a ford racing boss 302 block an punching it .30 over and putting my rotating assembly in it. Ill probably go with a set of AFR 225 head and a victor jr intake and a custom grind cam from comp cams. I currently have a vortech v7 ysi on the car pushing 13lbs of boost and i plan on cranking up the boost with it to around 25lbs or so. Will i acheive my goal with this setup? My ears are open for sugestions! Thanks, Adam
Old Jan 1, 2011 | 12:29 AM
hi5.0's Avatar
Try hitting up http://www.theturboforums.com/smf/index.php not quite the same type of power adder, but good source of info on tech, builds, etc. applicable to forced induction. More than a few Mustang owners there too.
Old Jan 1, 2011 | 10:20 AM
FordFan87's Avatar
Ok ill give them a try. Thanks!
Old Jan 1, 2011 | 02:51 PM
825LTRGT's Avatar
Don't forget that 800 hp is useless unless you get the car to hook!!
Sounds like a cool project though.
Old Jan 1, 2011 | 02:59 PM
FordFan87's Avatar
Well ive got lakewood 91/10's, 4 cylider springs and the sway bar removed up front and lakewood shocks, morroso springs and granatelli upper and lower controll arms out back. Im gonna run a 275/60-15 et street radial and in the process of getting an anti-roll bar. Im hoping all that will work good enough. I wont have money to tub it after the motor is done! Lol
Old Jan 1, 2011 | 06:24 PM
825LTRGT's Avatar
Sweet!
robjh22
Dec 14, 2015 08:41 AM
dohc97
Sep 27, 2015 06:32 AM
