-   Fox Mustangs (https://themustangsource.com/forums/f634/)
-   -   2nd Gear Grinding (https://themustangsource.com/forums/f634/2nd-gear-grinding-495804/)
deshawnb50 May 26, 2011 04:46 PM
2nd Gear Grinding
I was driving my 89 ssp and when I went to shift into 2nd I got a grinding problem didn't start until my stock clutch cable popped of I replaced tranny fluid and took the clutch cable off anyone have any ideas? I was planning to get a adjustable cable and a new clutch kit to go with it.
afr347strokerman May 27, 2011 09:08 PM
Tranny might need a possible rebuild...bad syncros maybe
BoogieNights May 28, 2011 09:27 AM
If it is only in second gear and it does it when you shift normal and doesnt do it when you shift slowly then your second gear syncro is going out.
