Proud New Owner '68 Coupe
VIN says San Jose, 289. It has the center console, automatic transmission, very minimal rust, frame & body are straight. I'll have to get back to you on the rest... once I build out the to do list. More photos when it's not raining.
That's a straight old car!
You mind telling is what you gave for it?
I would start with the interior....everything on the outside looks pretty great in the pics. Are numbers matching?
This is my high-level plan:
1. Pass inspection & get tags - asap
2. Get it driving right - this season
3. Interior - next season
4. Exterior - season 3
5. Accessories - season 4
To Do List #1 - Pass Inspection:
- Replace missing parking brake
- Replace rear brake drums
- Replace front brake shoes, resurface drums
- Replace 3 damaged brake hoses
- Replace upper ball joints
- Replace front wheel bearings
- Replace unevenly worn front tires
- Alignment
- Diagnose & fix non-functional horn
- Diagnose & fix dim headlight
- Replace bulbs in 1 turn signal & 1 reverse light
- Replace missing rear side markers & trim
- Replace bungee cord holding the battery down
- Service automatic transmission
- Replace improvised "fittings" between mufflers & tail pipes
- Replace windshield wiper blades
- Replace windshield washer fluid reservoir, get windshield washer working
