High whistle in engine bay
Old May 14, 2011 | 08:23 PM
tang65c's Avatar
Question High whistle in engine bay
I have a 65 6 cylinder that has developed a high whistle in the engine bay when the motor is running. When you listen it is very hard to figure where it is coming from. Wondering if any one else might have had this problem.
And what did you find out. Checked all the hoses they seem good. Any ideas?
Old May 15, 2011 | 09:40 AM
HOSS429's Avatar
legacy Tms Member
most likely a vacuum leak .. take a short piece of any kind of hose ( garden hose ) 3 feet or so and stick one end to your ear and move around the engine with the other end sort of like a stethiscope .. when you hear it loudest you are close .. then spray a little carb cleaner in that area and the engine should speed up a bit ..
Old Jul 15, 2011 | 07:30 AM
tang65c's Avatar
Found it
It was the hose going to the modulator on the tranny.
mustangsally_
Sep 18, 2015 05:35 AM
MustangGTCS13
Sep 17, 2015 07:38 AM
Sep 16, 2015 06:44 PM
Evil_Capri
Sep 11, 2015 08:39 AM
Sep 8, 2015 10:45 AM
