Convert 1968 manual brakes to power from 1967
I am new to this forum.
I have a 1968 coupe. 289. Automatic. Factory manual brakes. I have added front disc brakes. I have 1967 coupe parts car (automatic) and would like to move the power brake set up to the 1968. I read somewhere that the pedal and pedal brackets are different. Is that true? Will I need to swap out the pedal bracket assembly also? The brakes seemed fine when I drove the parts car. Should I replace the booster and master cylinder? Thanks |
Or am I over thinking this? Can I just buy a booster and hook up the vac lines? Do I need to change the pedal arm?
when KennyG sees this you will get an answer .. i`m not familiar enuff with the process ..
