65 Fuel Pump
Old 4/19/17, 07:56 AM
codeman94's Avatar
65 Fuel Pump
My car left me stranded. It acted like it ran out of gas even though it wasn't, so I'm guessing I need a fuel pump. Looks like the original might still be on there.
However I'm seeing a design difference in stock type replacements and performance brands like Edelbrock and Holley. The stock type has a canister under it (I'm guessing a filter) and the performance units don't.
My question is: Are the performance pumps designed to work without that canister filter, or will I need to re-use and somehow attach the old canister to it or get a new one?
I'd like to upgrade to a performance brand, but I don't want to take it apart and learn that I don't have all of the parts I need. Thanks!
Old 4/19/17, 08:03 AM
legacy Tms Member
HOSS429's Avatar
you just need to add an inline filter between the fuel pump and the carb if there is not one screwed into the carb already ..that pump can be a booger to put on .. it is spring loaded and can be difficult to get the bolts started straight ..
Old 4/19/17, 08:57 AM
ElkGroveFordGuy's Avatar
I recommend a filter before and after the pump.
that way if there is any debris in the tank it doesn't log the pump.
