Ford 7-Liter Engines Deciphered: 427, 428, 429
Impress your friends by knowing the differences between the Ford 7-liter engines!
By AJ Mawley - March 8, 2018
The Legendary Ford 7-Liters
Ever wondered what makes each of these Ford engines unique? The legendary Ford 7-liters are some of the most sought after engines in muscle car history! We will be discussing the similarities and the differences between the three and analyze their performance, which has lent itself to huge popularity.
>>Join the conversation about the 7-Liter Ford Engines right here in the Mustang Source Forum.
Ford 427
The Ford 427 is a legendary motor that is still synonymous with Ford's success in automotive racing. It was available as a top-oiler or side-oiler and was Ford's race-only engine. The top-oiler delivered oil to the cam and valvetrain before the crankshaft while the side-oiler pumped oil to the crank first and the cam and valvetrain second. The displacement was chosen because it was the maximum allowed by many racing organizations at the time. Ford developed the 427 by using the same stroke as a 390 but increasing the bore to 4.23" to create the extra displacement. The motors were built with high horsepower applications in mind by incorporating a thickened deck and sturdy cast iron construction. Most 427's were fitted with solid lifters for higher RPM stability and reliability. The Ford 427 was available in many variants to fit the desired racing conditions. For example, low-riser, medium-riser, and high riser heads could be installed from the factory depending on the fitment and flow capabilities needed in the desired race car. Overall, the Ford 427 was the highest performing motor Ford had built up to date and is still extremely valuable and rare today.
Ford 428
The Ford 428 was an inexpensively built engine that lacked some of the bottom-end durability incorporated in the previous side-oiler 427. More specifically, the numerous oiling improvements and cross-bolted main bearing caps were missing in the 428 making it less apt for performance driving abuse. Although the 428 is about the same displacement as the 427, it had a smaller bore (4.135" vs 4.23") and a larger stroke (3.78" vs 3.98") due to efforts to decrease production costs. As a result, the 428 was less rev-happy but it gained a low-end torque punch that was absent in the 427. The Q-code Cobra Jet 428 was rated at a very conservative 335hp @ 5600rpm. Some of the other unique facts about the 428 are that it's externally balanced and due to the different piston and connecting rod combos used by the factory. There are 4 different crankshafts that could be installed in the 428. Overall, the 428 is an amazing engine in its own way and reflects how productions costs and needs are incorporated into Ford's performance efforts.
Ford 429
The Ford 429 was developed under Ford's new "385" series which was an advancement from Ford's 427 and FE designs. The main aspects of the 429 that make it different from the other 7-liter Fords are the thin wall castings, longer bore centers, larger bearings, hemispherical canted valve heads, and rockers riding on fulcrums instead of rocker shafts. The Super Cobra Jet variant of the 429 was advertised to produce over 375hp, although independent testing rated it closer to 460hp.
For Ford's racing efforts, the 429 received aluminum heads to create the legendary Boss 429 which was used in NHRA and NASCAR events. These engines were known to produce well over 500hp making it a force to be reckoned with on and off the track. A similar aluminum head design was used on the Ford 302 to create the Boss 302 which was very successful in sanctioned events internationally.
The Legend Lives!
Now that you know more about the Ford 7-liters, you can impress your friends by spotting the differences and similarities between them at your local car show! Nowadays when electric cars and hybrids are taking over, it is easy to appreciate some of the most visceral engines made during the golden era of muscle cars!
For help with your maintenance and repair projects, please visit the how-to section on our sister site, MustangForums.com.
NEXT
BACK
NEXT
BACK
