Troubleshoot right front speaker
Old 12/3/16, 10:39 AM
Burnhaven's Avatar
I replaced the original Shaker 500 head unit with an alpine UTE 52BT. Everything is fine except I don't seem to get sound out of the upper right front door speaker. The woofer on that side seems fine.
What I don't know is if that speaker ever worked -- had the car about a year. I guess first step is to check from that speaker back towards the head unit. I'm hoping I don't have to dig into the dash and pull the radio again.
Old 12/3/16, 12:20 PM
SpectreH's Avatar
You could use an ohm meter to make sure that speaker hasn't open-circuited.
Old 12/3/16, 12:32 PM
Burnhaven's Avatar
I have a good multi-meter but it looks like accessing the speaker requires lots of stuff to be removed. And, I really don't want to tear the dash out again to access the speaker wires behind the stereo.
Old 12/3/16, 09:17 PM
SpectreH's Avatar
You should be able to check the speaker at the door panel, not from the dash unit side.
