351 Windsor Rebuild
Old 11/28/16, 10:24 PM
Gutie#12's Avatar
351 Windsor Rebuild
So i have a line on a 351 w out of a ford van. I want to drop it in my 65 mustang which currently has a 289 4 speed in it? Any thoughts on that move?
Also I think motor is fine but if i decided to throw a quick rebuild on it, what kits would be the best for around 300 bucks or so?
I want the Windsor obviously for the horsepower and cool factor what you think?
any help or ideas greatly appreciated.
Old 11/29/16, 07:29 AM
legacy Tms Member
HOSS429's Avatar
unless you do some things to beef up the 351 you will be very disappointed with the swap . they are not any better performing in stock form .. .. you would be better off hopping up the 289 ..
Old 12/3/16, 11:28 PM
Gutie#12's Avatar
what about a 1996 ford explorer 5.0 gt40 v8 complete motor? I heard those were good engines to put in?
Old 12/4/16, 09:14 AM
legacy Tms Member
HOSS429's Avatar
i am not familiar with those engines .. but i see them swapped in a lot so it must be a good thing .. others on here will know more ..
Old 12/4/16, 09:35 AM
legacy Tms Member
HOSS429's Avatar
but wait !! there`s more ... if your car is something special like a GT or at minimum a C or K code you will hurt its value with an engine change ...and again the 289 can be built to perform every bit as good as the 5.0..
Old 12/4/16, 12:38 PM
ElkGroveFordGuy's Avatar
Good bargain engine!
but if you do a cam swap which you will want to because the stock cam is a truck cam and stops making power at 4,500 rpm, you have to change valve springs which costs a couple hundred bucks, plus only certain headers will work because of the angle of the spark plugs on the GT40p heads.
If you have a good 289, I would just put some good heads, cam intake, carb and exaust and you can easily make 300 hp at the tires!
