crap something bad happened
Old 11/25/16, 03:02 PM
Winkawak's Avatar
While topping off my engine oil couple drop of water(sweat) fell in the engine, am i screwed? Car seems okay on my way home but not sure about long term damage.
edit
Im not offended at all, might sounds stupid to yall but to me its a legit question. I rather look dumb asking the question than not knowing. This is my first car so i still got much to learn and ill probably get more of you a holes on the way but hey its all part of the online experience.
Old 11/25/16, 03:55 PM
ElkGroveFordGuy's Avatar
That should not have any effect on the engine!
Old 11/25/16, 04:03 PM
Winkawak's Avatar
What amount would cause a concern? I always hear there should be no water mixing with engine oil, should i change my oil to be sure or is it too late since i drove few miles home after it happened?
Old 11/25/16, 04:07 PM
David Young's Avatar
Moisture gets into the oil all the time. Condensation happens and it gets burned off. You'll be OK.
Old 11/25/16, 04:11 PM
slow.stang's Avatar
David is correct, it's already evaporated and gone through the pcv and back out the exhaust.
Old 11/25/16, 04:27 PM
TheReaper's Avatar
You should probably check the air pressure in your tires.
Old 11/25/16, 04:35 PM
First off don't drive the car
Clearly you are not intelligent enough to operate a motor vehicle
Secondly you should always use birth control
Kotenukimen (12/2/16)
Old 11/25/16, 04:39 PM
slow.stang's Avatar
****, you guys are brutal.
Old 11/25/16, 06:18 PM
GrnT's Avatar
I think it could explode. Go to the parts store and ask for some canned steam. That stuf will fix your problem fast.
Old 11/25/16, 07:20 PM
What happened to the idea of no dumb questions!
You guys are brutal!
Funny but brutal!
Old 11/25/16, 07:31 PM
Winkawak's Avatar
Old 11/25/16, 07:43 PM
Sarge's Avatar
If that happened in a comic book, your car would probably get superpowers.
Old 11/25/16, 08:20 PM
Old 11/25/16, 08:36 PM
TheReaper's Avatar
I'll poke at you but I won't steer you wrong.
Old 11/25/16, 08:40 PM
GrnT's Avatar
Originally Posted by 2k7gtcs
Old 11/26/16, 12:16 AM
Joeywhat's Avatar
Toss a half gallon in there and you'll probably have issues.
Remember that when your engine is cold and warms up, condensation occurs. Once it reaches full operating temperature it's plenty hot enough to evaporate any water mixed in.
Old 11/26/16, 01:20 AM
Hey you took it in stride. How old are you, if you don't mine me asking? There might be some hope for our generation yet!
Old 11/26/16, 02:29 AM
Twin Turbo's Avatar
It'll be fine.......don't sweat it
Old 11/26/16, 08:09 AM
Received 1,679 Likes on 1,199 Posts
HA HAAAAAAAAAAA
I see what you did there.
Twin Turbo (11/28/16)
Old 11/26/16, 03:04 PM
Now I get it. (I'm blond)
