Tire pressure on wider tires
Generally wider tires, given the same load, will require less air. lowering or raising air pressures will effect handling too. I run a 255/45 up front at 41 psi and a 305/45 in the rear at 28 psi. I would run the rears at like 24 psi but the pressure sensor doesn't like that. The harder front tire is to help with any tramlining or nibbling and the softer rear tire is help with traction. So I would follow the recommended pressures and adjust from there.
I run mine between 32-35psi..
Received 1,498 Likes
For the street, I would run them up fairly high like 35-40 psi like Redonblack said. This will reduce the rolling resistance a little for a hair better mileage. It won't give ultimate maximum performance, but you can't use that on the street anyway.
For the track, the "optimum" is probably much lower, like 30-ish . . . but that is best determined by adjusting the pressure based on the amount of sidewall roll-over that you are getting on hard cornering, which really can only be done on the track.
mikes70mustang
Custom Vanity Personalized License Plates & Brackets /Delete Brackets
23
1/19/17 12:55 PM
buckethead1
12
6/2/16 07:04 PM
