ECM and wiring?
ECM and wiring?
Ok, so I have a 2004 converted to a 3V
Today I changed the cam sensor and road test and it was fine. The car came with an SCT tuner and the check engine light was not illuminating, so I programmed the car back to stock. After that the car will not start. I checked the fuel pump out and all wires at the connector are getting power to them. I can't find any wiring diagrams anywhere. I am starting to lean towards the ECM being no good.
Any other input would be great
Ok, here's some input... Don't post the same exact post you did here yesterday:
https://themustangsource.com/forums/...t-help-542172/
Because what you then do is split the attention and you'll get nowhere. Stay in the original thread for the best help, and be patient. More there, go there now.
orange3.9stang
5/1/16 07:33 AM
