2012-2013 BOSS 302
High RPM Lockout
Old 5/28/16, 09:28 PM
mikes70mustang's Avatar
High RPM Lockout
Has anyone only changed the clutch and fixed this problem? Seems like everyone did the mounts then shifter then clutch.
Old 5/28/16, 10:21 PM
redonblackpony's Avatar
New clutch resolves this problem.
My stock clutch was getting very hard to shift into 5th at the track during high rpm. During a track session One of the dampening springs tore through the metal and destroyed my clutch.
Installed a McLeod Twin Disc clutch and problem was solved.
Old 5/29/16, 08:59 AM
So basically you just replaced the clutch and didn't mess with the shifter and mounts and it works great? Seems like a cheaper option the. All the other stuff
Old 5/29/16, 10:17 AM
ford20's Avatar
I would just do the clutch and MGW Race and be done with it.
Old 5/29/16, 10:40 AM
Even with the stock clutch I had the Barton short throw shifter with the bracket. Hi rpm shifting is better with that shifter but not perfect. So far the clutch seems to have resolved that issue. I have had zero lockout or miss shift during high rpm's
Old 5/29/16, 02:30 PM
fking1's Avatar
Agree.
Spec Stage2+clutch & MGW solved lockout for me.
Old 5/29/16, 02:31 PM
fking1's Avatar
Barton & Blowfish only did not work for me.
Old 5/30/16, 12:48 PM
Dayve's Avatar
Did you get the 800 or 1000 HP one? Did you do the stainless steel lines too?
Dave
Old 5/30/16, 01:55 PM
I installed the RST (800). And yes, I did the braided stainless steel clutch line from McLeod. Clutch pedal feel is the same as stock
mlcinema
6/1/16 11:45 AM
Brets87
5/25/16 10:05 PM
dontOverSteer
5/20/16 07:19 AM
Dayve
2012-2013 BOSS 302
12
5/10/16 06:23 PM
Quick Reply: High RPM Lockout
