Now Available -Steeda S197 Mustang Clutch Spring Assist 95 lb/in (11-14 All)
Hello All:
You asked ... we listened!
We are now offering the Steeda S197 Mustang Clutch Spring Assist 95 lb/in (11-14 All) ... you can check it out here - http://www.steeda.com/steeda-s197-mu....6HKnpPMp.dpuf
Product Benefits
Improve clutch pedal engagement feel
Modulate your clutch engagement with ease
Piano wire construction with high tensile strength and high elastic qualities
Consistent spring rate and minimal sag even after repeated use
More linear clutch feel
Complete replacement of factory 200 lb/in clutch assist spring
Avoid slave cylinder damage due to removal of stock clutch spring
Steeda quality, backed by a lifetime warranty
Best Regards,
TJ
Product Benefits
Best Regards,
TJ
Copy, was just curious, that's all. I can't remember off hand, was there anything else that came out with the spring? If so, do you guys carry that as well? I thought there was a guide or holder or something but I can't remember it's been too long.
Hi TJ,
Maybe I'm missing something here......the assist spring is listed as an S197 part and the model years listed as 11-14. Would this spring help the touchy clutch release on my '06 GT?
I have a followup question: So is the theory behind this Steeda spring to make the clutch easier to depress? i.e. less stiff? Hmmmm... maybe it's just me, but I like the stiffness of the OEM clutch in my S197.
I think it's supposed to make it easier than without a spring at all, not easier than stock.
Hello JackStraw,
Sorry for the delay - but I spoke to the R & D team & they said the following
Best Regards,
TJ
It will not work ... because of the design we do not see the ability to make an aftermarket one. 05-10 works completely different
TJ
You can check out this article to get a full review & insight of the spring http://www.mustangandfords.com/how-t...great-results/
It's HARDER to press the clutch down with both of our spring offerings.
Best Regards,
TJ
Best Regards,
TJ
Please send me your order number to tim@steeda.com ... I will look into it & have your assigned sales rep follow-up with you soon after.
Best Regards,
TJ
Best Regards,
TJ
Please send me your order number to tim@steeda.com ... I will look into it & have your assigned sales rep follow-up with you soon after. Best Regards, TJ
Best Regards,
TJ
Best Regards,
TJ
This is what I know - these have been flying off the shelves & we have sold our initial supply.
Some of the springs may now being shipping out at a little later date. I have asked the sales professional assigned to each order, to follow-up with you directly.
I will hopefully have updates for you all sometime tomorrow.
Best Regards,
TJ
Best Regards,
TJ
Best Regards,
TJ
Best Regards,
TJ
