2016 GT uses 87 octane
I fueled up my car for the first time used 93 octane. A couple days later I was going through manual for something else and came across recommended fuel of 87 octane. I thought they would recommend a higher octane.. Would 93 burn too hot for newer motors causing damage? I'm not opposed to using 87 since it's cheaper..
The articles I have read say the difference in power between 87 and 93 is only 4 HP.
Modern high swirl cylinder heads with variable valve timing allows for very high compression ratios. The 2 liter in the Focus is 12.x:1 and it recommends 87 too.
Ford says on their website that GT power ratings were achieved using 93 octane gas. If memory serves, since day one, the Coyote has been 'premium recommended' (not the only car to do this, the base Corvette has been the same way since the C5 debuted).
No,it will not burn hotter.It will allow for more squeeze b/4 igniting . I use 93 only and usually alcohol free.
Fert Mosstank
'10-14 Exterior Modifications
7/27/16 07:11 PM
TMS Editor
3/20/16 08:10 AM
