How to make interior lights stay turned off when door is opened?
Old 10/27/10, 03:40 PM
JimmyM's Avatar
Hi,
I tried to find the answer myself by reading the manual, but this was nowhere to be found in the lights section.
I would like to know how to make the interior lights stay off right after I turn off the car or if my door is open.
Thank you
Old 10/27/10, 03:49 PM
Red Jay's Avatar
take a hammer and break the lights .....
seriously, their there for a reason. why would you want them off though?
Old 10/27/10, 03:57 PM
SynisterGT's Avatar
The lights in our 06 civic can be turned off if the door is open. For some people they feel like it might save the battery.
Old 10/27/10, 04:15 PM
MOTM Committee Member
stangfoeva's Avatar
I can do this on my '99 cougar too
Old 10/27/10, 04:28 PM
OAC_Sparky's Avatar
It's handy when you're girlfriend is in the car and you don't want the wife to find out...
Seriously though, there are times like when you're having a coffee in your car on night shift and you don't want the interior light to come on when you shut off the ignition or open the door. My Focus does that, the light comes on for 20 seconds when you turn off the ignition, but you can turn it off.
Old 10/27/10, 04:39 PM
Red Jay's Avatar
hmm, i dont think my Focus does that...well it does do it but only when i take the key out of the ignition.
Old 10/27/10, 06:23 PM
OAC_Sparky's Avatar
Don't know what year yours is but mine's an '05. Maybe it's because mine's a standard transmission. There's a switch on the dome light that lets you choose between AlwaysOff-OnWithDoors/Ignition-AlwaysOn.
Old 10/27/10, 06:40 PM
Red Jay's Avatar
mine is a 2010 and also is a manual transmission too. i dont think i have that on my dome light.
Old 10/27/10, 08:58 PM
2010MustangGT's Avatar
Is it fuse 25? or is that the one for the buttons?? hmmm.
Old 10/27/10, 11:12 PM
JimmyM's Avatar
When I'm stalking it gives away my position
I'm not concerned about the battery or anything like that. It's just that there are times when I don't immediately get out of the car, I don't want my entire interior illuminated. It isn't a big deal, I just thought it was strange that there isn't an option to turn it off, as most vehicles do.
I guess I will just live with it.
Old 11/1/10, 07:39 AM
watchdevil's Avatar
Easy to do a simple wiring modification behind the map light housing. All you need to do is break the connection that grounds the circuit when the doors are opened. If it is done right then all you need to do is switch the map light button on as normal if you want the lamps to light up. Alternatively, if you wish to leave the dome light function but just want to switch it off at will, install a small black rocker switch in the map light housing (where the convertible top switch would normally go) which will switch off the circuit.
Old 11/1/10, 08:16 AM
I am Shauny Clause
MOTM July 2010 Winner
Stinger1982's Avatar
we were shooting the car for a magazine last thursday night and we had to cover the lights to get interior shots cause there is no override on the dimmer (lame)
Old 11/2/10, 02:58 PM
watchdevil's Avatar
A simple 30 second solution would have remedied that. The dome/map light unit pops out with a tug of the hands and the connector can simply be unplugged.
I had to work on mine today as one of my Blue LED lamps failed and had to be replaced.
Old 11/2/10, 03:00 PM
I am Shauny Clause
well sure i could have un plug them, but I didnt feel like dis-assembling my car in the dark....... instead we used a photo reflector that i held from the back seat
Old 11/2/10, 03:39 PM
stangfoeva's Avatar
I was cycling through the options to change mycolor and I saw and option for AUTOLAMP with settings of 0, 10, and 20. I meant to mess around with it to see if that controlled it, but I forgot.
That could do the trick or it could be the auto-headlights....
Old 11/2/10, 03:58 PM
I am Shauny Clause
thats headlights
Old 11/2/10, 04:23 PM
stangfoeva's Avatar
thats headlights
Dang, that's what I feared...
Old 11/2/10, 05:43 PM
Siber Express's Avatar
If you use a screw driver and stick it in the latch and latch it the lights go off after the timer goes off, not the remedy for the OP but it will turn off the lights for pics on the inside of the car.
Just remember to open it before you close the door.
Old 11/7/10, 11:23 PM
jeremyalan's Avatar
I'm in process of wiring a switch into my dome light to remedy this problem. I also hate dome lights coming on at night. From what I've read the wire you need to cut into to break the circuit is the gray-purple wire when you pull the dome assembly off. I will confirm this with a multimeter tomorrow
Old 4/29/16, 02:01 PM
miltonrios49@gmail.com's Avatar
Hi,
Thank you
Watch "Easiest trick to keep dome lights OFF in your mustang when your door is open!" on YouTube
https://youtu.be/j1DyRtAL6hs
Quick Reply: How to make interior lights stay turned off when door is opened?
