Winter Tire advice needed - '15 GT PP
I just got a '15 GT 50th Anv. Edition and I live in Chicago area...so need a winter swap out for wheels/tires!
I'm sure this may be covered, but could find specifics...
- What winter/snow tires would you recommend?
- Would you just stay with stock wheel size? I believe the 50th Anv comes standard with the Performance wheel size (with limited edition wheels). I was going to find some stock take-offs of aftermarket wheels to make the swap easier. ...thoughts?!
The stock PP wheels should be easy to find, though they're a PITA to clean, so I don't know if I'd use them for snow wheels. The mesh style will trap a lot of snow for sure. They're also staggered - not the best for snow tires, since I'm assuming you'd want them to last a few seasons and want to be able to rotate.
I'd go for a square set of the GT350 style wheels so you can use the same tire size all around.
Or maybe even a set of these, if they clear the PP Brembos (I believe they do, but you'd want to verify with LMR): https://lmr.com/item/M1007DC199LGB/2...nt-Black-Wheel
Then you could run a 255/40/19 all around. Better to have narrower tires in the snow anyways right?
Thanks...can I do same size all around? The "staggered" ones even in the summer tires, can't be rotated, right?!
Yes you can do the same all around, though you may actually want to go with a little bit taller size since your stock is 275/40 in the rear. If you did 255/40, your speedometer would be off a little, which you could fix with a tuner.
Or, you can just do a taller tire all around that matches the same height as 275/40/19.
And correct, you cannot rotate your stock summer tires. They're different sizes and widths front/rear. The rears won't even clear the front without a spacer.
Just looked up winter tires in 245/45/19 for you, which was a factory size on 10-14 cars. Exact same height as your 275/40/19 rears. Do 245/45/19 on a set of 19x9s all around and you'd be good to go!
Originally Posted by Joeywhat
I would get 18s if they'll fit. The taller sidewall will be considerably more forgiving on poor winter roads.
I ended up finding some of the black PP "take offs" with the stock tires on ebay for just over $1K...I will get snow tires for them and keep the stock ones for replacements later...seem like like a good path!?
Almost everyone will tell you to get Bridgestone Blizzaks for winter tires. They are good but expensive. I went with Firestone Winterforce tires this past winter and had absolutely no problems. I am in the Chicago area so I drove in the same stuff you do. They are less expensive than Bridgestones.
Yup, Blizzaks. They are expensive but cheaper than touring your car or killing yourself. I had them in Colorado on both of my old mustang and a nitrous RX-8 and drove the cars year round-up. Even when trucks and 4x4's were getting stuck all around me, I never slipped.
Had them on FWD cars as well, they perform amazingly.
