steeda or koni
steeda or koni
anyone tried the steeda pro action shocks and stuts? my 12gt (brembo)has the stock front springs and 55d rears with roush uca and frpp lca and just want a good non adj. replacement set!it looks like its gonna be koni STR.T or the steeda pro action;s.
I got the pro action's and ultralite springs about 18k mi ago as a set from steeda. Either one will give you what you want. Both are better than stock. Lowering springs will help even more.
If you go with 11-14 struts , you will need caster camber plates or re-use your factory strut mounts. This however is not advised, because several people have had them fall apart while re-installing them. I went with 05-10 struts and then used gt500 mounts, on my 2014.
PM sent to you via Modded Mustang.
Here is what our shocks & struts offer:
Product Benefits
Exceptional ride quality
Properly valved for your Mustang
Better ride than competing brands
Engineered & manufactured to exceed OE standards
Great for street and track action!
Lifetime warranty
Made in USA
- See more at: http://www.steeda.com/steeda-pro-act....EHiirX8A.dpuf
Best Regards,
TJ
Product Benefits
Lifetime warranty
Made in USA
Best Regards,
TJ
9/24/15 08:15 PM
9/16/15 06:44 PM
