High RPM Gear Lock Out on 2013 Boss 302
Just be careful of the sinter iron clutches as the dust is magnetic and collect over the crankshaft position sensor over time and can lead to your P03XX misfire codes. If you have these kind of clutches it is good to pull out the CPS every few oil changes and clean it off and just do the relearn if you have the X4.
Here is a picture of someone that was throwing misfire codes with the clutch dust attached to his CPS.
It is just the clutch compound. You have your organic compound clutches like the RST, and then the sinter iron compunds like the RXT. The sinter iron clutches just as a nature of the design grab hard and can hold a lot more torque which is why you see them in these high HP applications and are favored more so than the organic compounds.
I believe the Spec Stage 2+ does not have an iron compound clutch, but I am not positive. I think they start with the metallica in their 3+ and up clutches.
russgray32
'10-14 Exterior Modifications
18
12/19/15 11:45 PM
