Steeda S550 Billet Aluminum Vertical Links (2015 GT, V6, EcoBoost) - Now Available!
And yet another upgrade rolls off the assembly line here at Steeda! Our Steeda S550 Billet Aluminum Vertical Links (2015 GT, V6, EcoBoost) are in stock and readily available!
These S550 integral/vertical links are made from 6061, aircraft grade aluminum. They feature CNC machined delrin bushings, and billet steel bushing sleeves and spacers, providing less deflection than the rubber bushings in the stock vertical links, yet does not add any NVH!
Our Steeda vertical end links will not flex under load like the OE links, and will give a better feel of the rear suspension, which helps the rest of the suspension assembly perform as it should. The install is simple and comes with all necessary hardware!
Key Product Benefits:
- Provides better handling characteristics
- Installs easily, with basic hand tools
- Will not flex under load
- No increase in NVH
- Made in the United States with high grade materials
Product Photos (the second to last one compares ours to OE):
Best Regards,
TJ
Best Regards,
TJ
ustabawannab
8/5/15 08:32 PM
7/30/15 06:47 AM
Ecoboost
7/25/15 06:32 PM
