This looks like the exhaust crossover seen on the IRS undercar shots
Old 8/9/12, 07:53 AM
PTRocks's Avatar
This patent seems to explain the apparent 'box' seen at the front end of the exhaust we've seen on the mules. a more complex replacement for the H-pipe
Attached Thumbnails This looks like the exhaust crossover seen on the IRS undercar shots-resonator1.jpg
File Type: pdf
Old 8/9/12, 07:58 AM
Twin Turbo's Avatar
Thumbs up
Good spot.........................now try and find the patent for the new bodystyle
Old 8/9/12, 06:47 PM
Vickstang's Avatar
Great info and sharp eye!
Old 8/13/12, 02:40 PM
montreal ponies's Avatar
he's on a mission, i'm sure he'll find it. Don't underestimate the guy, i know him....
Old 8/13/12, 03:41 PM
Juice's Avatar
Ooooh, its 1969 all over again!
Old 8/13/12, 03:46 PM
Juice's Avatar
Old 8/14/12, 03:36 PM
That's called a Prochamber lol...
Old 8/20/12, 10:17 AM
Mossberg's Avatar
I was thinking the same thing, since I own a ProChamber.
They are different though
Old 8/29/12, 04:16 AM
zoeblue's Avatar
Excellent, I just passed this onto a colleague who was doing a little research on that.
Old 8/29/12, 09:26 AM
Overboost's Avatar
What are the benefits to this design? It's an interesting concept. As long as you can still easily change exhaust components like on the '11+ cars, I think it's fine.
Old 8/29/12, 09:47 AM
908ssp's Avatar
Part of the thinking behind the chamber patent drawing above is harmonic tuning. When both exhaust pipes sides are identical a harmonic from one side will reinforce the harmonic from the other side raising the volume and creating a drone. When one side is slightly different than the other this harmonics will fall at different pitches this will smooth out the tone and be less likely to boost any one set of frequencies and therefore have less chance of harmonic drone. This has been used for years. I did it when I moved one of my M80s back and left one forward. The differences in position made a slight difference in frequencies from each side eliminating the slight drone when the two mufflers were in the same place.
Old 9/14/12, 12:08 AM
06GT's Avatar
beddy intradasting
oneeyedgiant
11/16/15 12:23 PM
10/2/15 01:00 PM
9/24/15 08:15 PM
9/8/15 10:45 AM
Quick Reply: This looks like the exhaust crossover seen on the IRS undercar shots
