2013 GT - loud thump under floor when going up a driveway at an angle
I just picked up my car from the dealer. I had two issues; 1 the noise over bumps (lower control arms) and 2 a loud thumping sound under my floor when I go up driveways at a certain angle. The lower control arms were fixed but I still have the thump issue
It feels like someone is punching under my floor. Doesn't happen when I go up a driveway straight, only at an angle, for example making a right turn into a driveway. Has anyone else had this issue before? I want to take it in again and perhaps I can explain it better if there are others with the same issue.
I just picked up my car from the dealer. I had two issues; 1 the noise over bumps (lower control arms) and 2 a loud thumping sound under my floor when I go up driveways at a certain angle. The lower control arms were fixed but I still have the thump issue.
Deysha
I have the same problem. I also have a very pronounced creaking coming from the passenger front when the weight shifts that direction on left turns or curves. This happens at all speeds. I also still have the thump from the driver's rear. I tried torquing the PHB brace bolts to 70 ftlbs and it is quieter but still there.
Deysha,
I'm still in germany and the last place where I had work done was crappy. If you could help me find another place that would be awesome. I can PM you my info again if you need it.
Deysha,
I just picked up my car from the dealer. I had two issues; 1 the noise over bumps (lower control arms) and 2 a loud thumping sound under my floor when I go up driveways at a certain angle. The lower control arms were fixed but I still have the thump issue It feels like someone is punching under my floor. Doesn't happen when I go up a driveway straight, only at an angle, for example making a right turn into a driveway. Has anyone else had this issue before? I want to take it in again and perhaps I can explain it better if there are others with the same issue.
Deysha,
Deysha,
Remember, since you’re in Germany, you should call the Germany Customer Relationship Center at +49 (0) 221 903 3333 for assistance. You can also contact the Overseas Military Sales Corporation (OMSC) who can assist with service-related issues. OMSC can also help you find a participating service center. Please contact them at 1-800-669-6183 or 9-011-49-6173-704-256.
Deysha
Another thing to add: If you are tightening suspension components, torque them down to specifications. They can make noises if they are to loose or to tight.
So I had to actually go back to dealer yesterday afternoon for a road test cause they couldn't duplicate the sound (they probably thought I was crazy). So I drove with a service manager and he heard the sound and was amazed (by the way I explained exactly how, why and what occurs, but its ok). Got the call this morning at apparently was the sway bar. They changed it. I will pick it up in a few hours and see what has changed. Been driving a piece of crap Mazda for the last 4 days. Can't wait to get rid of it!
Thump is gone!!!!!!!!!!!!!!
Still have the squeeking and crackling in dash when going over large cracks. Service guy drove my car for 10 miles and couldn't duplicate sound. Only happens once in a while, I guess I can live with it....for now.
Looks like i am getting the same grunt/creak/squeak/chirp noice from the rear axle OR LCA specially going over bumps, small potholes..its **** annoying now.
I already had same issue from front which was fixed (70%) last year from my ford dealer.
So, looks like i will have to take appt. asap to get these items checked. I already have due date for oil change so might as well get this everything done at one shot.
Will keep everyone posted.
Cheers
Hansthak
Cheers
Hansthak
CURRENTLY NOT ACTIVE ON THIS SITE DO NOT USE PM FEATURE!
Cheers
Hansthak
Cheers
Hansthak
Hope to hear from you soon!
Brittany
Rando
8/25/21 11:12 AM
