Notices
Mustang 3.5L Ecoboost engine swap
Old 5/22/16, 11:36 AM
  #1401
Popeye010's Avatar
Pics of injectors
Can you possibly send me some closeups of how the injector bungs are mounted in the F150 manifold or at least post them up?
Old 5/22/16, 11:48 AM
  #1402
Popeye010's Avatar
Also do you have a part number for the an fitting that you used that goes to the factory fuel rail?
Old 5/22/16, 12:02 PM
  #1403
GatorV6's Avatar
Looks familiar
For real though, this is great progress! I'm finishing up my intercooler plumbing and starting on wiring everything right now and under-hood space is definitely becoming an issue lol but it's not this bad. This is some great inspiration though, I'd love to give that aux injection a try at some point!
Old 5/22/16, 07:24 PM
  #1404
Ecostang's Avatar
The nitrous is wired up, TPS sensor is programmed, the heater works, purge works, and nitrous solenoid works under WOT....at least it works with the engine off.
You can see under the console lid there is a group so buttons. Arming, heater, automatic bottle opener (will install later) and the purge button.
What a mess of wires!!!
Old 5/22/16, 07:29 PM
  #1405
Ecostang's Avatar
On top of the console around the e-brake handle I have a master arming switch for everything nitrous related, it powers the small group of switches inside the console.
The other switch is the master arming switch for the line loc, the red button is the to engage the line loc.
Old 5/22/16, 08:20 PM
  #1406
Ecostang's Avatar
I believe if you check towards the beginning of the thread you will see several pics of the injector install. Check it out and let me know if you need something else.
Here's the adapter
Old 5/22/16, 08:27 PM
  #1407
Ecostang's Avatar
Originally Posted by GatorV6
Looks familiar
Lol, yep that's pretty close!
Ya it all barely fits, tetris comes to mind. For aux fuel check this out, not for 3.5 yet.
http://www.stratifiedauto.com/index....roducts_id=255
Old 5/22/16, 08:48 PM
  #1408
Popeye010's Avatar
I meant the adapter that is on top of the manifold, the one that is in the auxiliary fuel rail.
Old 5/22/16, 09:06 PM
  #1409
Ecostang's Avatar
Oh the fuel rail, it's from a 2011+ 3.7 mustang.
BR3Z9F792A
http://parts.autonationfordwhitebear...name=fuel-rail
Old 5/22/16, 09:08 PM
  #1410
Popeye010's Avatar
BR3Z9F792A
Lol..... no I know it's a stock fuel rail it's the adapter that goes into that fuel rail... I see you have braided steel line feeding that rail,,,,,, I need that connector that goes from the braided line to the factory fuel rail.
Old 5/22/16, 09:12 PM
  #1411
Ecostang's Avatar
Ahhh, let's try this
http://www.ebay.com/itm/222064893467?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old 5/22/16, 09:19 PM
  #1412
Popeye010's Avatar
YES!!!
Old 5/23/16, 12:35 PM
  #1413
Popeye010's Avatar
Excuse some of my questions and sort of thread jack but where did you find the shouldered injector bungs.
I milled the lower down to the gaskets so I can use all stock heater hoses and not use the F150 water pipe. I was going to mount the injectors in the spacers as I did on the Taurus manifold but I like your approach better. I'm fighting for space but have a high rise hood. My ultimate goal in running this setup, first N A,,, but then to use the 3,7 heads on a 3,5 short block and avoid the whole control pack issues. Just not sure how well the 3.5 to 3.7 heads will blend. But it would save a **** load of money and get me a forged block.
Taurus setup.
Old 5/23/16, 01:05 PM
  #1414
Ecostang's Avatar
Here's a link to the bungs I used
http://www.ebay.com/itm/EFI-electron...EDaovg&vxp=mtr
Cool project, I would think the heads would fit fine.
EDIT: fixed the link
Popeye010 (5/23/16)
Old 5/23/16, 01:21 PM
  #1415
Popeye010's Avatar
Thanks for the inspiration to get my butt going again and the saving me hours of research for what I need in small parts. Also that install of injectors on top is something I never even thought of.
Old 5/23/16, 01:30 PM
  #1416
Ecostang's Avatar
Cool, no problem!
I didn't find this until after I started working on mine but someone else has installed injectors in an aluminum manifold. Www.ecopowerparts.com sells them, his name here is mtxexpert I believe. So depending on which manifold you want you can decide how to install the bungs.
Old 5/23/16, 01:35 PM
  #1417
Popeye010's Avatar
Well if I go Procharger or a current turbo kit I can use my Taurus manifold as it turns the stock 3.7 direction and I know it already works as is NA. The F150 NA should work better as it has much more volume... anyways, I like the bolt on F150 setup a lot better!!!
Old 5/23/16, 01:46 PM
  #1418
Ecostang's Avatar
I wish that my setup would have worked with the Taurus manifold because I would have used it. I'm sure you know but for everyone else the Taurus and F150 air inlet orientation is completely different.
The reason why I would have preferred the Taurus manifold is because it was a PITA to expoxy the bungs and get them sealed to hold pressure. It's very difficult to apply the expoxy to the inside of the manifold. Welding the aluminum would have been less "ghetto" overall. My main concern is that I'll be spraying fuel inside a plastic manifold, if there's a backfire the plastic will not survive but the aluminum most likely would.
If you want pm me for the custom made plates I have for pressure testing the manifold. That's the only way I found my leaks.
Popeye010 (5/23/16)
Old 5/23/16, 09:10 PM
  #1419
Ecostang's Avatar
I installed the nitrous nozzle in the aluminum 90 just before the throttlebody.
Old 5/23/16, 09:11 PM
  #1420
Ecostang's Avatar
It was thick enough to drill and tap
Quick Reply: Mustang 3.5L Ecoboost engine swap
