It's Dyno Time!
The Mach or 2+2 or any other classic is one thing, but a modern chassis with an old engine is another. With a classic the lines, the history grab you and a great engine finishes you off. With a repowered version of the same car you saw 50 of on your way to work, that repower has to be exceptional. Otherwise, cammed 351. Same dimensions, same idle, and possibly same performance I respect the concept, but you didn't cheap out on the build, why cheap out on the follow through?
Now that it's been retired from daily driving duties, my induction options going forward are (sorted by estimated price):
Dual quads -$1800
Vic Jr with fogger nitrous setup - $2k
Quad webers - $4k
6/71 blower with dual quads - $5k
I chose the Air Gap intake because I wanted it to be streetable and because it ain't a drag car by any means. I figured the Vic Jr would have been wasted on it. Now that it's been retired from daily driving duties, my induction options going forward are (sorted by estimated price): Dual quads -$1800 Vic Jr with fogger nitrous setup - $2k Quad webers - $4k 6/71 blower with dual quads - $5k
Heck, I never even criticized your parts choice, never mentioned the intake, only mentioned the cam because your peak rpm goals are tied to it.
It's your car and your money. If you are totally happy with 80% potential out of the motor and having the cache of saying you have a 427 in there then the only person that matters is happy. I, and and any other folks not as happy as you do not matter.
That being said, even though you can make plenty of power with the RPM, and there are LOTS of choices for a Windsor, IMO nothing looks as killer on a n/a motor as IDA's..
Listen, I spoke up because in the same thread it appeared you went from asking for help getting more power and fixing the 5600rpm drop off to agreeing you didn't need any more.
Video of final run:
Received 2,174 Likes
Well I'm happy for you and it ain't even my car! Who cares how many ponies you got! I think it's awesome and even better yet you have future tweaking capability if you are so inclined to do!
I'd definitely make sure it's not running lean when at higher RPMs...the extra ponies might not matter but your engine remaining a single unit sure does.
If I have to cut the hood, it's gonna be a 6/71 with dual quads.
I think quad webers will fit under the hood.
Assuming a 15% parastic power loss through the trans, the car is making 504 hp at the flywheel.
We actually talked about that over the weekend. Make an adapter plate for a blower intake, mill off the top of the KB, make a carb adapter, and we're off and running. But it would be cheaper just to get a 6/71 setup.
Cheaper, true, but you're doing something different from most everyone else, and can you imagine the power? I'd think twice about milling the case too much though.. Why not work it out EFI and put a bug catcher on it, feeding it normally? That would be pretty sick to see/hear.... I wonder how many ci that blower could actually feed efficiently since it's past 1700hp under 6L..
