Creaking sound from front when driving over speed humps
I drive a 2014 Mustang GT Premium and I noticed that there's this creaking sound (and feel) when driving over speed humps (small or big ones). I wonder if this is normal.
Let me know if you've experienced this and what the fix could be so at least I could also tell the dealership when I go on a check up.
Thank you
Thank you
Legacy Tms Member
Yes, at least to me its normal action of the shocks doing their thing. Likely something with the rebound control. It just an idiosyncrasy. Now, if you're hitting speed bumps at 60mph the noise could be indicative of something else. :-)
Thanks! I already included it in the list of things for them to check. I'm just about to do the first 1000 KMs PMS check up. When did you start hearing these sounds anyway?
Haha, no of course not. I always go slow on those speed bumps!
Thank you
Thank you
Also, I know we’ve made arrangements with the Overseas Military Sales Corporation (OMSC) to assist with service-related issues. OMSC can help you find a participating service center, which should be able to assist you with the key. Please contact them at 1-800-669-6183 or 9-011-49-6173-704-256. I hope this helps.
Deysha
pauljohnpena,
If you check under the Warranty and Service Issue section you'll find your answer. I just had my lower control arms replaced because of that noise which is from the bushings and my '14 GT turned one month old yesterday. The TSB to reference is 12-8-24 (GRUNT/CREAK/CHIRP/SQUEAK NOISE FROM THE FRONT LOWER CONTROL ARM OVER BUMPS).
pauljohnpena, If you check under the Warranty and Service Issue section you'll find your answer. I just had my lower control arms replaced because of that noise which is from the bushings and my '14 GT turned one month old yesterday. The TSB to reference is 12-8-24 (GRUNT/CREAK/CHIRP/SQUEAK NOISE FROM THE FRONT LOWER CONTROL ARM OVER BUMPS).
Hello again, pauljohnpena! Since youre in the Philippines, I recommend calling the Ford Group Phillipines, Inc. at +63 (49) 541 5000 for assistance. Also, I know weve made arrangements with the Overseas Military Sales Corporation (OMSC) to assist with service-related issues. OMSC can help you find a participating service center, which should be able to assist you with the key. Please contact them at 1-800-669-6183 or 9-011-49-6173-704-256. I hope this helps. Have you addressed this with your Ford Dealer, Darth Paul? Deysha
pauljohnpena,
under section C) CHECK AND REPORT FOR SQUEAK NOISE WHEN GOING OVER BUMPS, read below for the TSB no.
Get this done ASAP. I thought it was normal on my 12 GT and I put heavy miles on it. After about 20k miles i noticed my tires were wearing very unevenly on the outer tread. I took it in to Ford and they replaced the control arms and did something else (can't find the repair sheet). Squeaking has been gone since. But my tires got worse. When I got a new set of tires put on, the mechanic mentioned how way off my alignment was.
When you get this done, i strongly advise getting your front alignment checked as well.
