BEST street/autocross performance tire in 285/35/19 for Brembo/Track Pack wheels?
#41
Apparently those Continental, are the only 285/35R19 tires that can be used with the 9x19 wheels. Probably they will be my next tires, I'm very temped by their wide size. Presently I have 275/40 R19 Michelin Super Sport on my brembo wheels, they look great, handle great and represent no issue with my 3.73 gear. I did not bought them in 285 size, because they needed at least 9.5x19 wheels, too bad.
When I get some wear on the GY F1 tires I have now they will be replaced with Conti Extreme DW's.
#42
Thanks, M3Hunter... where did you hear that the ExtremeContact DW were approved for 9" wheel? Is that from Continental directly?
If so, you just ended my several month long tire debate.
#44
The DWs run small. I would never run that tire after my experiences with them on the Teslas. They wear extremely fast, become noisy with little mileage on them, the narrow tread makes the sidewall not protect the outer rim...no thanks. The DWS though, I would definitely run those again.
#45
This is valuable feedback. Thanks. The reviews on Tirerack are glowing but most of these people have very few miles on them.
Do you recall if the DWS run comparably small?
EDIT: DWS seem to be a less high performance tire... much higher treadware rating, much less "positive space" in the tread design. Hmmm...
#46
This is valuable feedback. Thanks. The reviews on Tirerack are glowing but most of these people have very few miles on them. Do you recall if the DWS run comparably small? EDIT: DWS seem to be a less high performance tire... much higher treadware rating, much less "positive space" in the tread design. Hmmm...
For an all out autocross tire though, I'd look elsewhere.
#47
#48
This is true. TW ratings are not regulated per se, but in reality they're just a manufacturer's rating based on the rest of their lineup. I forgot about that.
#53
#54
#55
I had a great driving experience with my 275/40R19 Michelin Pilot Super Sport square setup mounted on my stock brembo wheels, no complain at all they match great my 3.73 gear, probably my front ones tended to follow a bit the road groves, but on standing water they are superb and did a great job at the track curves, did a lap of 30 secs. vs a bmw m3 (V8) 29 secs. just my brakes quit on me.
Now I want to move up to Bridgestone Potenza RE -11, but I'm not planning to change my Brembo wheels that I really like, and I know that their 285's aren't the right ones for my 19x9 wheels. They have very few options from were to chose, I was thinking to go squared with their 265/35R19.
What do you all think?
#56
They are nice looking, but heavy. I use my stock wheels for street duty, but for track applications I upgraded to 19X9.5 wheels. You can fit 275 or 285 wide tires, and with RE11s I'd go with 9.5" wide rim for sure. This will allow you to keep proper sidewall angle which is important for performance driving.
Plus there are good tire options in 285/35-19 or 275/40-19, and 265 wide tires will have less grip than same tire in the wider size.
#58
275/35-19 may also be worth considering. Similar problem with less top speed in each gear, but to a lesser extent, but lots of tire choices.
#60
Hopefully someone who used them on a Mustang can chime in. There are a few guys I work with who auto=x and do open track days (WRX and Focus ST) who have nothing but good things to say about the Direzza Star Spec.
