2014 Gt Track Pack Oil Specs... Fords specification?
I have looked every where but I can not seem to find the Ford specification for the Track pack oil requirements. All I can find it 5w / 50 and an API rating?
I am looking for oils that meet that spec. After researching seems that if you put oil back in that has more zinc than the normal oils then you will not get the famous tick.
Thankx
Can you let us know your results? Also, where'd you get this info?
and I'm curious to hear more. I have plans to start using Mobil 1 15W-50, which is a racing oil had has more zinc starting next year.
NAPA is running a special on Mobil One for September of $5.99 a quart and they make 5W50. It beats the $9 a quart you'll pay for Motorcraft plus it's better oil.
Scott
Scott
Seriously though, do you know what part of Ford specs M1 doesn't pass? The general consensus here seems to be that M1 is better than any Motorcraft oil (and so are Amsoil, Pensoil etc). Also hare is a good informative thread on oil lab results:
http://www.svtperformance.com/forums...302-UOA-thread
Scott
