99-04 Stock Clutch Pedal Adjustment - The Mustang Source - Ford Mustang Forums
SN95 Mustang 1994-2004 Mustangs
Thread Tools Search this Thread
Old 6/15/12, 05:37 PM   #1
allthefreakypeople's Avatar
I'm writing for help regarding this How-to article:
http://www.corral.net/tech/drivetrain/clutcha.htm
My 'stang is my daily driver and while I normal drive almost exclusively highway w/o traffic, today I got stuck in hours of stop & go traffic. My left calf really got a workout. I'm frustrated with the "stiffness" of the stock clutch and how low to the ground I have to push the clutch in for it to engage.
Anyways, I found this write-up on how to adjust the level where the clutch engages, but I'm having a lot of trouble finding this "hook" that is referenced in the article. This "hook" is apartently what you push up to make the adjustment.
Can anyone help this dummy out?
allthefreakypeople is offline   Reply With Quote
Join The Mustang Source
Join TheMustangSource.com Today - It's Totally Free!
Are you a Ford Mustang fan? If so we invite you to join our community and see what it has to offer. Our site is specifically designed for you and it's a great place for Ford Mustang Fans to meet online.
Once you join you'll be able to post messages, upload pictures of your stang, and have a great time with other Ford Mustang fans. Whether your an old timer or just bought your Mustang you'll find that TheMustangSource.com is a great community to join. Best of all it's totally free!
Join TheMustangSource.com Today! - Click Here JOIN FOR FREE
Old 6/19/12, 12:42 AM   #2
cntchds's Avatar
It's pretty close to the gas pedal up there. If you take a flashlight in there just look up at what moves when you push the clutch.
cntchds is offline   Reply With Quote
Old 6/19/12, 12:36 PM   #3
Hail To The eVe
TMS Staff
skunk21's Avatar
The adjustment isn't going to change the stiffness.
also never adjust a clutch for "feel" or "driving style" total myth adjust the clutch for function.
correctly adjusted the clutch will begin to grab about 1/2 way up its travel. If the clutch grabs right off or very close to the floor then it is adjusted to loosely and will cause difficulty putting into gears, cause the car to roll on flat surfaces and cuase premature clutch/transmission wear.
If the clutch grabs to high or at the very top of it travel then it is adjusted to tight ( or your clutch is wasted if adjusting the cable will not fix the high pedal!! ) a clutch that is giving to high will cause it to constanly disengaging when driving.
you want the clutch to grab about 1 1/2 inches or so of the floor and have about 1 inch of end play on the pedal when the clutch is released.
my 2 cents worth.
skunk21 is offline   Reply With Quote
Old 6/20/12, 09:53 AM   #4
Thanks for the info. It seems like the clutch engages way too close to the floor. I haven't actually measured it but I'd like to try this adjustment. I know it won't help with the stiffness but may make the constant shifting a little easier.
I've spent a lot of time under the seat and I see the parts that move when I push in the clutch. However, I still can't find this "hook" that makes the adjustment. Could someone post a picture for me???
Old 6/20/12, 10:26 AM   #5
Hail To The eVe
TMS Staff
skunk21's Avatar
does your car still have the stock quad? In the pic the "hook" is under just under the teeth of the quad. look at the pic, over to the right you see part of the teeth of the quad, just under that is a that plastic hook looking part.
Old 6/20/12, 04:21 PM   #6
Yes everything in my car is stock. I just looked again where you described but I can't figure it out. I know I'm a dummy, but an arrow in the write-up picture wouldn't have hurt!!
Thread Thread Starter Forum Replies Last Post
255/40/19 to 275/40/19 Kestral Suspension, Brakes, and Tire Tech 5 9/6/15 12:50 AM
Looking for a good Service Department North NJ/South NY Area ssjbuu Warranty and Service Issue 6 8/28/15 09:55 AM
My "new" 1998 GT Vert mrp5150 SN95 Mustang 4 8/23/15 07:29 AM
Noises when clutch disengaged? Mug-stang 2010-2014 Mustang 3 7/31/15 11:25 PM
Clutch Blown? stewarts359 Warranty and Service Issue 8 7/21/15 04:39 PM
Tags
adjustable, clutch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010, The Mustang Source
