TWIN TURBO custom build
Here is the specs on the build of my twin turbo.
Nyles at http://www.sschassis.com/ in Schiller Park, IL
did all the custom work on the turbos install. Along with by brother
Pete at Pete's auto Clinic in Chicago they did all the heavy work and installations.
The car runs like around town like it was factory fresh........
WON"T stomp on it untill 1000 miles mark. So far 560 miles.
Only problems so far..... small oil leaks and a few codes.
Thanks for looking.........comments welcome
2005 Mustang GT
TWIN TURBO BUILD SHEET
MOTOR 2005 Ford 4.6Aluminum Block
Livernois STAGE 3 heads 5 axis CNC machined, valves,
Intake flow rate 300 CFM - Exhaust flow rate 215 CFM
1mm oversize (35mm) intake - 1mm oversize (38.5mm) exhaust valves,
Livernois VCT Lockouts
Crower Cams stage 2
Felpro Head gaskets
Ford V10 Flex plate
04 Cobra Crank
Manley Pro Series Rods w/ L19 bolts - 9.0 to 1
APR/SP2000 Head Studs
APR Main Studs
Steeda CMDP Deletes
Main Bearings
Rod Bearings
New Lifters, Oil pump, rear main seal,
New Ford Timing Chain, tentioners and guides
Autolite HT0 spark plugs
CUSTOM TURBO SET UP
Headers-Stainless steel stepped 1-5/8” to 1-3/4”
Down pipe Custom Stainless steel 2-1’2”
Inter-cooler Set up 3” & 4” tubing
TURBOS - TWO (2) GTR3582R Garrett
2- 38 mm Tial Waste gates
1- Tail Blow off valve
V-Clamps Stainless steel
Hose Clamps Stainless Steel
Silicon Hoses High Temp
Air to Air Inter-cooler custom made **flow rated @ 1400 cfm
FUEL
Duel Ford GT w/ -6to-8 fuel lines all upgraded lines, hoses and fittings
Metco Fuel rail
80# Ford Injectors
SPEED SERVICE
Bore block 20 over with torque plate
Install main studs and line hone with torque plates
Surface block deck
Cut 10/10 & polish cobra crank
SUSPENSION front
BMR Tubular K-Member
BMR Upper control arms
Steeda Radiator Support
SUSPENSION rear
Metco Drive shaft safety loop
Heavy Duty Upper Control Arm Bracket
Upper adjustable Control Arm
Control arm relocation brackets
Adjustable Lower Control arms
Differential Bushing
Adjustable pan hard bar
TRANSMISSION
Ford 5R55S
TCFord 5R55S Super StreetFighter™
(1200hp)I Super StreetFighter™/StreetFighter Transmissions
Super StreetFighter™ Torque Converter (3500 RPM Stall Speed)
Custom Fab oil pan and oil pick up
Windage tray
EXTERIOR
Steeda Side Window louvers
CDC Hood Scoop with built in turn signals
CDC Chin spoiler
Sequential tail lights
Rear gas cap and lock removed, leaded and smoothed
Black Chrome mess grill upper and lower
Hood Struts
Clear front signals
2005 Mustang GT
Crower Cams stage 2
Felpro Head gaskets
Ford V10 Flex plate
04 Cobra Crank
APR Main Studs
Steeda CMDP Deletes
Main Bearings
Rod Bearings
CUSTOM TURBO SET UP
FUEL
Metco Fuel rail
80# Ford Injectors
SPEED SERVICE
Surface block deck
SUSPENSION front
SUSPENSION rear
TRANSMISSION
Ford 5R55S
Windage tray
EXTERIOR
CDC Chin spoiler
Hood Struts
Clear front signals
