JET Power-Flo Throttle Body Spacer
#181
Go to Sear's, Lowe's, Home Depot etc and buy an easy out set. They don't cost that much. It's not hard to do. I know Don could do it!
#182
Originally posted by y22kc@July 29, 2005, 8:53 AM
I ordered mine last night, and I have the JLT intake. Should be here Tuesday or so, I'll report what happens as far as fit and performance.
Awesome - keep us JLT CAI folks posted! (cause I was worried about this myself)
#183
Originally posted by don_w@July 29, 2005, 8:58 AM
Will they also come and get the broken piece out of the intake manifold? :bang:
UPDATE: After my 20-mile commute this morning (a combination of stop & go, and highway traffic), I can safely say I believe throttle response is definitely more crisp in the sub-3000rpm range. I notice it when under normal acceleration (no WOT chances during rush hour... hehe), like pulling away from a light, or when passing on the highway. It's not an "OMG" type feeling, but it is a improvement well worth 100 bucks or so. It will be a bonus if it helps at the track, too!! Add me to the satisfied buyers list.
Don - did you disconnect the battery during install???........
#184
YES, you disconnect the batter during install cause you are removing the plugs from the throttle body. The thing with the plugs, if you don't know how to get them off the throttle body, here's how they come off.
1. Pull the red plastic clip/cover on the plug until you can't pull no more.
2. Pinch the middle area of the plug
3. Pull the plug out
Took me a while to figure that out but i finally got it and its easy to remove.
#185
Actually, no... I did not disconnect the battery.
#186
#188
Well darn it. I've been following this post since the start, and now I have to buy one even though I plan on getting the BBK TB sometime. Thanks guys for making me spend money . . . there goes the tint job.
Now off to spend money . . .
#189
Well, disappointing news everyone - even though UPS had two days to try to deliver my spacer, they managed not to on either day (they're real pita's about having someone sign for it). And, to my surprise and disappointment, they aren't even open tomorrow for me to go pick it up. That, and it turns out I have to work all weekend. So my fun little plan of dyno'ing the spacer on Saturday and sharing with you all the results will not happen, as Monday will be the earliest I'll get the spacer. Total f'n bs, and I'm pissd.
Sorry to disappoint. If no one beats me to it, though, I'll do it next weekend.
#191
Same here... UPS just drops and goes... even if someone is home!!
I just ordered a digital video cam online, and they dropped it off at the front door. :nono:
#192
Ok I'll bite
I am going to go ahead and order the intake spacer.
But how do I go about extending the passenger side hose?
Is there a specific type of hose or can I just go to Loews or any automotive part store and get one. What length?
Thanks for the help guys
#193
Originally posted by trublustang03@July 29, 2005, 10:08 PM
Ok I'll bite
Ok I'll bite
#194
I will wait for the numbers also. I have used them before but then they were called adapters. Installing a four barrels on manifolds that were not drilled for them. Don't have a clue if they worked. The carb sure did.
#195
Originally posted by don_w@July 30, 2005, 12:05 AM
I just stopped by the local Autozone today and bought a 12" piece of 3/8" ID vent hose (cost me $1.07 w/tax). I cut the stock plastic vent line in half. I used about 4"-5" of the hose to "couple" the two stock pieces together by sliding the stock pieces inside the hose about 1.5" - 2" on each side. It is a nice, tight fit, so no clamps or anything is needed (in fact, I had to put a couple drops of 3-in-1 oil on the stock parts to slide the hose over them).
#196
Originally posted by MaverickMLFD371@July 28, 2005, 5:19 PM
He's got the steeda CAI, which retains the factory arm & hose and the factory hose does not stretch anymore than what its at right now......
NO, actually he has...uh..I mean I have the Steeda CAI and a C&L intake hose.
[attachmentid=29086]
#197
Originally posted by 169stang@July 28, 2005, 9:55 PM
That's why I posted the dyno sheet. I assume the lag is where the upward curve slightly dips between 3000 and 4000 rpms? Besides the SOTP feeling, I'm just curious if that TB spacer would take that dip out of the upward curve.
Even though the dip shows to be 3 to 4 k on my dyno sheet also, that is not where the flat spot was. It was actually 2, to 3300 rpm on mine.
#198
Originally posted by Burke0011@July 29, 2005, 6:25 PM
Okay - THAT's what I wanted to know - cause Bryan brought up a good point about disconnecting the battery and the car 'resetting' itself - I wanted to make sure that was not what generated the better throttle response - but Don if oyu didn;t and are experiencing better performance........ CRAP I just might have to pop $100 for this puppy..... (as long as it fits with a JLT...)
OH yea sure...when I say it works and that I also did not disconnect my batter, no one listens. Yet Don says the same thing and now suddenly everyone is buying one and installing with no care of disconnecting the battery...fine then!
#199
#200
Originally posted by Burke0011@July 31, 2005, 12:42 PM
Sorry Doc - was reading fast and in a hurry posting... I missed that you hadn't disconnected... no offense meant....
