Fuel cutoff switch
Old 11/16/05, 05:23 PM
TexaStang's Avatar
The switch on the driver side near the floor -- can it be used liberally for anti-theft purposes?
Old 11/16/05, 05:39 PM
9 is not my lucky number.
dustindu4's Avatar
it's just a reset, no turn on and off
Old 11/16/05, 05:45 PM
TexaStang's Avatar
Ah bummer
Old 11/17/05, 12:56 PM
Tyson's Avatar
what is the purpose of the switch? what does it reset?
Old 11/17/05, 02:34 PM
gmichael's Avatar
On my 1991 Explorer I cut the wire and found the engine wouldn't start. So, I ran a wire up to the center console and put a small black switch in and had a home-made anti-theft device. Don't know if it will work with the 2006 Mustang
Old 11/17/05, 03:01 PM
DDStang05's Avatar
FUEL PUMP SHUT-OFF SWITCH FUEL
RESET
This device stops the electric fuel pump from sending fuel to the engine
when your vehicle has had a substantial jolt.
After an accident, if the engine cranks but does not start, this switch
may have been activated.
The fuel pump shut-off switch is
located in the driver’s footwell, by
the hood release
To reset the switch:
1. Turn the ignition OFF.
2. Check the fuel system for leaks.
3. If no leaks are apparent, reset the
switch by pushing in on the reset
button.
4. Turn the ignition ON.
5. Wait a few seconds and return the key to OFF.
6. Make another check for leak
Gene62 (6/1/21)
Old 11/17/05, 05:11 PM
05fordgt's Avatar
Hey Dustin, that isn't entirely true. I have heard stories back in the day, (I mean late 80's early 90's) of mechanics taking a small hammer and playing practical jokes on friends. They would tap the car in JUST the right spot to trip the fuel reset switch. If you had a small hammer, you COULD tap the switch area, which would trip the switch, and make the car not start. The switch in gereral is sensitive by itself, but when a car is connected to it, the jolt has to be substantial, OR in the RIGHT spot, for it to work. It doesn't hurt to try it, really (at least that is what I have heard).
Old 11/17/05, 07:01 PM
Mongoose's Avatar
RESET
the hood release
button.
I see this is your very first post so I ask you to please read the question before making the post.
Old 11/22/05, 10:10 AM
nbk13nw's Avatar
Mine has tripped several times without reason that I can think of. Once while driving on interstae, as I cam off onto a side road, I suddenly lost power and coasted into a parking lot. The first time I pulled up to a pump, filled up the car and it would not start. I ended up playing with it for two hours trying o figure out why I had no fuel, ended with a tow to the dealer. they replaced the switch, but since then it has happened three more times.
Old 11/23/05, 05:37 PM
WERKED 66's Avatar
when i was towed recently to the dealer when my car just shut off while drving that was the first thing i checked...i was told by the service mechanic that sometimes when power shifting or sport shifting ..sometimes it can be setoff.....by hitting it with your foot...
Old 6/1/21, 02:27 PM
Gene62's Avatar
It appears my 2004 Mustang has a fuel pump cut off at the rear behind the drivers side tail light.
10/2/15 01:00 PM
irobles
1994-2004 V-8
9/20/15 04:30 PM
Mrmiles1369
9/11/15 07:23 PM
Quick Reply: Fuel cutoff switch
