Fuel cutoff switch - The Mustang Source - Ford Mustang Forums
Fuel cutoff switch
Thread Tools Search this Thread
Old 11/16/05, 06:23 PM   #1
The switch on the driver side near the floor -- can it be used liberally for anti-theft purposes?
TexaStang is offline   Reply With Quote
Join The Mustang Source
Join TheMustangSource.com Today - It's Totally Free!
Are you a Ford Mustang fan? If so we invite you to join our community and see what it has to offer. Our site is specifically designed for you and it's a great place for Ford Mustang Fans to meet online.
Once you join you'll be able to post messages, upload pictures of your stang, and have a great time with other Ford Mustang fans. Whether your an old timer or just bought your Mustang you'll find that TheMustangSource.com is a great community to join. Best of all it's totally free!
Join TheMustangSource.com Today! - Click Here JOIN FOR FREE
Old 11/16/05, 06:39 PM   #2
9 is not my lucky number.
dustindu4's Avatar
it's just a reset, no turn on and off
dustindu4 is offline   Reply With Quote
Old 11/16/05, 06:45 PM   #3
Ah bummer
Old 11/17/05, 01:56 PM   #4
what is the purpose of the switch? what does it reset?
Tyson is offline   Reply With Quote
Old 11/17/05, 03:34 PM   #5
On my 1991 Explorer I cut the wire and found the engine wouldn't start. So, I ran a wire up to the center console and put a small black switch in and had a home-made anti-theft device. Don't know if it will work with the 2006 Mustang
gmichael is offline   Reply With Quote
Old 11/17/05, 04:01 PM   #6
DDStang05's Avatar
FUEL PUMP SHUT-OFF SWITCH FUEL
RESET
This device stops the electric fuel pump from sending fuel to the engine
when your vehicle has had a substantial jolt.
After an accident, if the engine cranks but does not start, this switch
may have been activated.
The fuel pump shut-off switch is
located in the driver’s footwell, by
the hood release
To reset the switch:
1. Turn the ignition OFF.
2. Check the fuel system for leaks.
3. If no leaks are apparent, reset the
switch by pushing in on the reset
button.
4. Turn the ignition ON.
5. Wait a few seconds and return the key to OFF.
6. Make another check for leak
DDStang05 is offline   Reply With Quote
Old 11/17/05, 06:11 PM   #7
05fordgt's Avatar
Quote:
Hey Dustin, that isn't entirely true. I have heard stories back in the day, (I mean late 80's early 90's) of mechanics taking a small hammer and playing practical jokes on friends. They would tap the car in JUST the right spot to trip the fuel reset switch. If you had a small hammer, you COULD tap the switch area, which would trip the switch, and make the car not start. The switch in gereral is sensitive by itself, but when a car is connected to it, the jolt has to be substantial, OR in the RIGHT spot, for it to work. It doesn't hurt to try it, really (at least that is what I have heard).
05fordgt is offline   Reply With Quote
Old 11/17/05, 08:01 PM   #8
Mongoose's Avatar
Quote:
RESET
the hood release
button.
I see this is your very first post so I ask you to please read the question before making the post.
Mongoose is offline   Reply With Quote
Old 11/22/05, 11:10 AM   #9
Mine has tripped several times without reason that I can think of. Once while driving on interstae, as I cam off onto a side road, I suddenly lost power and coasted into a parking lot. The first time I pulled up to a pump, filled up the car and it would not start. I ended up playing with it for two hours trying o figure out why I had no fuel, ended with a tow to the dealer. they replaced the switch, but since then it has happened three more times.
nbk13nw is offline   Reply With Quote
Old 11/23/05, 06:37 PM   #10
WERKED 66's Avatar
when i was towed recently to the dealer when my car just shut off while drving that was the first thing i checked...i was told by the service mechanic that sometimes when power shifting or sport shifting ..sometimes it can be setoff.....by hitting it with your foot...
WERKED 66 is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Morimoto XB Projector Fog Lights Installed austin101385 '10-14 Shelby Mustangs 3 10/2/15 02:00 PM
Electrical issues on 2014 mustang captainEO Warranty and Service Issue 1 9/24/15 09:42 PM
Brake switch or shortage problem irobles 1994-2004 V-8 6 9/20/15 05:30 PM
Brake switch irobles 1994-2004 V-6 0 9/17/15 03:09 PM
Fueling issues Mrmiles1369 2005-2009 Mustang 2 9/11/15 08:23 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
© 2010, The Mustang Source
