What are "tunes"?
What are "tunes"?
And how do they work? Being an old guy that is used to points, plugs, and a timing light, this past summer I purchased a '14 GT. What is the procedure for a "tune"? Does this work by altering the peak horsepower and torque at different RPM's? I would guess this would be detrimental to gas mileage and warranty. Thanks.
It alters how the ECU (computer) interacts with the vehicle. There are a TON of parameters that the vehicle's computer can control, and the tune can change some of those to increase power, decrease throttle lag, and alter how the transmission shifts if you have an auto. Basically, it does a lot of what you used to do with carbed engines, but instead of doing all the tweaking yourself with a couple tools, you're telling the computer to make all those tweaks.
A tune may or may not decrease your mileage; in some cases it can increase it. It may or may not void your warranty, it depends on what exactly is being warrantied, and if the tune caused the issue. If a tie rod breaks prematurely then a tune will not effect such a warranty claim in any way.
Simply stated, a tune reprograms the ECU (Engine Control Unit). You typically need a flash device/tuner, i.e., SCT, Diablosport, etc. A "tune" can improve performance, mileage, etc., by changing the air/fuel, timing, rev limiter, shift-points(automatic), etc.
You generally need a "tuner" to load... and more importantly- store your OEM settings in the event that you would want to return the car back to stock... or load a different tune, i.e., going from a 93 performance tune to a 91 torque tune.
Yes, a tune "can" effect your warranty, but would only apply damage that occurred as a direct result of the tune- see Magnuson–Moss Warranty Act.
That about sums it up... Others can chime in for further details.
Check out this thread below for a description at a technical level
https://themustangsource.com/forums/...e-look-530110/
-Matt
-Matt
Then is the tune from the factory a compromise of performance, economy, and emissions? I would think any change in tune would be detrimental to at least one of those or it would have been done at Ford. What is the procedure to do this? Do you purchase a "flash device" for one cost and then another cost in purchasing data to download to it?
Factory calibrations are slightly limited to reduce the onset of torque, and in turn, reduces the amount of parts that break. This saves Ford a good bit on warranty work.
Yes, if you purchase a flash device from us (Redliners) it comes with 3 free tunes with updates for life.
Check us out! http://www.redliners.com/
Feel free to PM me or email with any questions. matt@redliners.com
-Matt
Since you have a '14 Gt, if your GT was manufactured after July 2013 you can get a trackey and have the best of both worlds. Using the Trackey will load a Tune from Ford racing and using your old key will load the stock tune. It's pretty cool. Check out the link to Ford racing
http://www.fordracingparts.com/trackey/default.asp
So what is the true and correct answer and where does the burden of proof lie?
Ford can NOT detect that a aftermarket tune has been installed vs an session with IDS as long as the PCM has been returned back to stock.
Source: I am a former a OEM software engineer. (Meaning I used to work a portion of the software that goes inside the PCM). See all my other posts on this forum
Cheers,
-Matt
I purchased my tuner from American Muscle and had it preloaded with a a performance tune for 87 octane a performance tune for 93 octane and a race tune for 93 octane. The tunes were from Bama tuning. To retune the car, you plug the flash tuner into the OBDII port located under the dash on the driver's side. The tuner will store the original parameters.
When you order the tuner, Bama Tuning will ask what you have for performance modifications (mine was a cold air induction system) and they will set the tunes for that.
I have an automatic transmission and have the performance 93 tune in my car. My gas mileage went up, I average 16 in the city and 23 to 24 on the highway when I set the cruise control at 80.
Read my thread linked few posts above.
Cheers,
-Matt
Cheers,
-Matt
See this Tread:
http://www.allfordmustangs.com/forum...1-07-07-a.html
Are you sure? Apparently Ford says they can tell and there is a TSB 11-07-07 from ford to watch out for people who have flashed their cars and then flashed them back to stock when bringing cars in for warranty work.
See this Tread:
See this Tread:
In fact, the whole thing reads like a scare letter, it's only purpose to make it sound like Ford will know as to keep people from tuning their vehicle then wanting warranty work. There is so little definitive information in that TSB, I don't really know what use it is to service departments.
I don't know how valid this is but my understanding is that they can tell how many times changes have been made to your ecu. They can't tell what. My service advisor told me that it isn't a given that it would the void the warranty but it makes the process much longer and Can lead to a denial of service. I figured a would play it safe and wait.
Ford can NOT detect that a aftermarket tune was installed, there is no "magic dust" left behind from an aftermarket tune. Now, if you leave the aftermarket tune installed...then yea, thats a no brainer...
For instance, if you owned a VCM and IDS, and flashed your PCM with the stock Ford tune 20 times, its going to throw out that same red flag as if you wrote a custom tune to it 20 times.
Cheers,
-Matt
Our one time tunes are $50 with free upgrades for life. (I brought back the same price as when I was working with BamaChips, I think the price wars has gotten out of control). Feel free to PM me or email me with questions! matt@redliners.com
Expect 15-20 rwhp and 20-30 rwtq with just a tune.
-Matt
Cheers,
-Matt
