Replacing tie rod end - The Mustang Source - Ford Mustang Forums
Go Back   >
2005-2009 Mustang S197 Discussion & News
Thread Tools Search this Thread
Old 10/18/11, 10:06 AM   #1
My 2006 GT needs a tie rod end on the driver's side. Will changing it neccesitate an alignment?
jay06GT is offline   Reply With Quote
Join The Mustang Source
Join TheMustangSource.com Today - It's Totally Free!
Are you a Ford Mustang fan? If so we invite you to join our community and see what it has to offer. Our site is specifically designed for you and it's a great place for Ford Mustang Fans to meet online.
Once you join you'll be able to post messages, upload pictures of your stang, and have a great time with other Ford Mustang fans. Whether your an old timer or just bought your Mustang you'll find that TheMustangSource.com is a great community to join. Best of all it's totally free!
Join TheMustangSource.com Today! - Click Here JOIN FOR FREE
Old 10/18/11, 10:28 AM   #2
fdjizm's Avatar
If you don't put it exactly how it was as far as turns on the rod/length, yes.
fdjizm is offline   Reply With Quote
Old 10/18/11, 10:50 AM   #3
repacing tie rod end
I thought that you could replace without re-aligning by "counting" the threads when removing and replacing. I'm just unsure whether ALL replacement tie rod ends are exactly the same length. Of course, if they're not, counting threads won't work.
Brings me to the next question----What brand tie rod end was used as original equiptment? If I gotta buy the tie rod end anyway, if I know what brand is there now, I might as well buy the same brand. I probably have the best chance of that being the same length.
In any case, thanks for the reply.
Old 10/18/11, 11:09 AM   #4
I bet its a ford part.... I kid. When you remove the old one be sure not to move the tire. The old one should plug right in or you can measure and get yourself very close to where is is supose to be.
Glenn is offline   Reply With Quote
Old 10/18/11, 11:21 AM   #5
redpony05's Avatar
Ya I replaced the tie rods on my 05 GT and as long as it's the same/stock/oem part the length should be the same. I just verified that they were the same length visually and they were. A trick I used instead of counting threads is to back off the jam nut on the tie rod just far enough to sandwich a credit card (or similar card) between the nut and the tie rod, so that when u put the new one on you just sandwich the card again (nut should have stayed in same position) and then remove the card and just tighten down the jam nut. Worked for me, but only when using oem replacement parts... I later installed steeda tie rod ends (bumpsteer kit) and since they're adjustable I got the length wrong and the card trick didn't work as well.
redpony05 is offline   Reply With Quote
Old 10/18/11, 06:18 PM   #6
slidejob's Avatar
I use home made toe plates to measure all my cars. Your car may be out of alignment & by trying to count threads etc, you are just putting it back to the wrong spec. Look at this pic & make something out of aluminum or wood & measure the front & rear to get your toe. Real easy & accurate.
http://www.saferacer.com/longacre-to...?productid=486
slidejob is offline   Reply With Quote
Old 10/18/11, 07:05 PM   #7
fdjizm's Avatar
Why count threads? get a marker make a mark, get to that mark with the new rod end lol
overcomplication.
Old 10/18/11, 08:48 PM   #8
ford4v429's Avatar
I'd just mark/tape measure across the front/outside edges of the tires, get it back as close to that as you can, thats plenty close enough to drive it to the alignment shop...if the tie rod was worn at all, odds are the bushings have settled/compressed a bit too, etc...
I kick myself for not buying the alignment stuff at the auction where I got my lift - I just wanted the lift, but a couple trips to the alignment shop woulda paid for the alignment hardware I didnt bid on...DOH!
ford4v429 is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Sct3 tuner question Glenn General Mustang Chat 5 9/23/15 09:37 AM
Car and Driver Lighting Lap 2015 results (GT and Ecoboost) MRGTX 2015 - 2018 4 9/16/15 09:08 AM
bought a gt500 front end DEPUTY62 2005-2009 Mustang 3 9/12/15 12:12 PM
Mustang rear end in 1968 cougar 1001yos Ford Discussions 0 9/8/15 11:05 PM
Just lowered my 2010 with Steeda package robjh22 Suspension, Brakes, and Tire Tech 4 9/8/15 01:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010, The Mustang Source
