Sponsored by:
Sponsored by:
Front end noise
Old 12/16/08, 06:38 PM
ptaylor_9849's Avatar
Front end noise
I recently brought my 07 GT to the dealer to have the TSB performed on the front strut mount replacement because my car was exhibiting noises on bumpy roads. Kinda sounds like something is loose. Well after the replacements went in the noise is still there. Is anyone else having this problem or is your front end quiet?
Old 12/17/08, 06:34 AM
Doogie's Avatar
It might help to include any mods you might have installed, especially with the front suspension.
Old 12/17/08, 07:12 AM
I have not done ANYTHING to the suspension other than this service bulletin which didn't work. http://www.stangnet.com/images/stori...s/07-18-02.pdf
Old 12/17/08, 07:12 PM
ksguy73's Avatar
Mine always makes a rattling noise from the front, like something is loose, when going over the washboards going onto base. (I don't know what they're called but they're the grated bumps that make alot of noise when going over them) I have never worried about it since that is the only time it does it and they are pretty rough no matter how slow you go. Other than that it is quiet. I did have a squeeking/squaking noise from the front several months ago and it turned out to be bad struts from the factory but nothing ever sounded loose with that.
RRRoamer
1/19/17 05:27 PM
jc46002003
4/15/16 03:00 PM
awoychosky123
'10-14 Exterior Modifications
8/18/15 08:30 AM
Mackitude
8/17/15 04:14 PM
Quick Reply: Front end noise
