2006 Automatic Shifter assembly
Old 7/31/15, 10:23 AM
hpb50's Avatar
Thought I had to remove the T handle to remove my console - so I did. Now I can not get it re-assembled correctly. As it is shifter and steering wheel do not lock, and key cannot be removed. Have tried assembling several times but can not get to work correctly. Bought a Haynes Service manual - it shows nothing. Please help!
Old 8/1/15, 06:22 PM
07 Boss's Avatar
The manuals won't show anything because the assembly is not meant to be serviced, just replaced. Not sure how the handle effects the steering lock and such. I gave my stock shifter away a long time ago so I can't go and investigate it. Does the car start? I mean does the neutral safety work?
Old 8/3/15, 03:03 PM
hpb50's Avatar
The Neutral Safety does not work, steering wheel lock does not work, and key can not be removed from ignition switch. If i disconnect battery and push up little white lever on lower right of shifter, then wheel looks and key can be removed. Once I reconnect battery it will unlock steering when I turn key, but key can not be removed and steering will not lock again. There is a plastic rod goes down through shift lever (see pic). The angle on the top mates to and angle in the T handle. Looks like when you push the left shifter button the shift should go down and release the shifter. But there has to be some kind of a trick to properly seating the rod in shift lever. Can't figure it out. Appreciate any suggestions.
Old 9/27/23, 09:20 AM
Administrator, Shop Manual PDF Poster, Parts Locator & Spam Bot Eliminator!!
05stangkc's Avatar
Received 2,507 Likes on 1,844 Posts
https://themustangsource.com/forums/...spring-549852/
Your Answers are Here!
Mgb,
Kc
Old 9/27/23, 02:54 PM
THE RED FLASH ------Moderator
m05fastbackGT's Avatar
Received 1,949 Likes on 1,578 Posts
Kevin! I highly doubt if anyone receives a response from hpb50 anytime soon, as his last forum activity was from over 8 years ago.
Old 9/27/23, 02:58 PM
05stangkc's Avatar
I'm Always Looking At What Guests Are Reading So I Know What is Still Relevant, A Guest Was Reading it So I Updated the Link For Him! Likely Spooks Em A Bit! I'm Always Lurking For Truth Justice and The American Way! Heh That's Pretty Good! I'm Gonna Use That More Often!
Wow My Keyboard Just Had a Meltdown! Does Not Like The Port is Was Plugged into! Weird!
Mgb,
Kc
Old 9/27/23, 03:03 PM
Mgb,
Kc
Good call, as I need to remember to check first if the posts are being read... Like you said, we're all still learning on the go lol.
odiaz
4/26/16 11:27 PM
jkstrader3
10/9/13 06:33 AM
Mike Mustang
1/17/12 07:57 PM
TAYLOR
8/27/11 10:42 PM
watchdevil
05-09 Interior and Audio Mods
5/14/08 12:25 PM
Quick Reply: 2006 Automatic Shifter assembly
