2005 GT Battery Replacement - The Mustang Source - Ford Mustang Forums
Go Back   >
2005-2009 Mustang S197 Discussion & News
Thread Tools Search this Thread
Old 7/27/11, 03:17 PM   #1
rickoshay's Avatar
I think the battery in my 2005 GT just called it quits. The car is a garage queen with just under 8K miles and I've always used a Battery Tender on it while garaged. It was fine three months ago when I took it for inspection. Today just "click, click", not enough power to work the windows even.
Put a 10 amp charger on it & after an hour and a half the charger indicated "full" so shut off and re-connected the batt cables. Still dead!
Knowing that there were some issues with these original batteries (BXT-40R) back when the cars were new, I'm thinking of upgrading to the BXT-96R battery. After all, it is six years old now. Will this battery work OK in a 2005 model? BTW, my car is equipped with the Shaker 1000. Thanks!
rickoshay is offline   Reply With Quote
Join The Mustang Source
Join TheMustangSource.com Today - It's Totally Free!
Are you a Ford Mustang fan? If so we invite you to join our community and see what it has to offer. Our site is specifically designed for you and it's a great place for Ford Mustang Fans to meet online.
Once you join you'll be able to post messages, upload pictures of your stang, and have a great time with other Ford Mustang fans. Whether your an old timer or just bought your Mustang you'll find that TheMustangSource.com is a great community to join. Best of all it's totally free!
Join TheMustangSource.com Today! - Click Here JOIN FOR FREE
Old 7/27/11, 06:55 PM   #2
Planeswalker's Avatar
Get an Optima IMO.
Planeswalker is offline   Reply With Quote
Old 7/27/11, 07:45 PM   #3
rickoshay's Avatar
Thanks but I'd prefer to stick with Ford components if possible.
Old 7/28/11, 06:29 AM   #4
NJ3
The BXT-96R is what I went with when my OE battery died. It fits but your old battery insulator won't fit, so you'll need the correct one if you want to keep OE appearance. I had my new battery die after about a year but I received a replacement under warranty.
NJ3 is offline   Reply With Quote
Old 7/28/11, 08:41 AM   #5
rickoshay's Avatar
Thanks for the reply, Ned. I just found out about the size difference while at the Ford store. I went ahead and ordered a 40R and will pick it up this afternoon.
Interesting that the newer 96R is rated at 500 cold cranking amps while the 40R is 590 CCA.
Old 7/28/11, 02:04 PM   #6
Paris MkVI's Avatar
I'm on battery #5. For reasons I cannot fathom, the dealership just loves continuing to replace batteries under warranty. You'd think they would come up with something to address the issue once and for all.
Paris MkVI is offline   Reply With Quote
Old 7/28/11, 03:14 PM   #7
rickoshay's Avatar
Just got the new battery in and all appears good except I need to look up the procedure to reset the driver's side window. Won't auto up and doesn't drop when door is opened.
I really can't complain. The Battery Tender has done a good job for the past six years and I think this problem was due to a cell shorting internally.
Old 7/28/11, 03:57 PM   #8
karman's Avatar
Post
The 96R is not an upgrade.
The 40R only came on early cars with the active alarm.
The 40R was the upgrade.
The issues were not with the batteries. They were with the cars.
Your battery just got old.
karman is offline   Reply With Quote
Old 7/29/11, 05:48 AM   #9
CalStang'07's Avatar
[QUOTE=rickoshay;6112681]Just got the new battery in and all appears good except I need to look up the procedure to reset the driver's side window. Won't auto up and doesn't drop when door is opened.
Your Mustang owner's manual explains just how to reset your windows operation programing. Easy stuff, takes one minute or less. CalStang
CalStang'07 is offline   Reply With Quote
Old 7/29/11, 03:51 PM   #10
97svtgoin05gt's Avatar
Mine is also somewhat of a garage queen and it was dead again about 3 weeks ago. I put the charger on it and all seems fine once again. Once they won't hold a charge they're done. I will be starting mine over the weekend. We'll see how that goes. I'm also on the original battery.
97svtgoin05gt is offline   Reply With Quote
Old 7/29/11, 10:03 PM   #11
area5179's Avatar
The battery may not the problem. My GT is a daily driver and I have the shaker 1000 radio. It may be the Shaker 1000 amp. it will still draw power even when the car is shut off. Every winter after i got my GT if I didn't use my car after 2 or more days it would need a jump. This past winter I took the fuse's out just for the Shaker 1000 amp and it sat for a week because of all the snow I got and it fired right up. I've had my battery replaced once under warranty for this issue and then replaced it again afterwards with an Optim yellow top. The first time it happened I took it to the dealer and when they tested for power draw while the car was off the Shaker amp would still draw with the car copmpletly shut off.
area5179 is offline   Reply With Quote
Old 7/29/11, 11:19 PM   #12
Five Oh Brian's Avatar
Why stick with a crappy OEM battery? I went with an Optima redtop last winter in my '07 GT and couldn't be happier.
Five Oh Brian is offline   Reply With Quote
Old 7/30/11, 10:00 AM   #13
karman's Avatar
Wink OEM battery is OK
Quote:
The Optima is not really necessary. Gel cell is not required for regular driving.
Both my '06 OEM batteries are still fine.
My truck's battery is now 8+ years old and still works and test fine.
I will probably replace the truck's this year anyway.
I use Interstate batteries for replacements.
Old 8/1/11, 12:50 AM   #14
I have Active Alarm plus Shaker 1000 and actually went to the smaller 96R Walmart Energizer since they didn't offer the 40R. It's been working great so far. I still haven't bought the smaller battery insulator/fume blanket yet.
Lime GT is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
2015 Mustang GT premium leather seat issue kponypower GT 17 1/28/16 07:27 PM
FS - $150 - BMR Strut Tower Brace (2005 - 2009) godspunk32 Parts For Sale 2 1/21/16 07:09 PM
FS - $225 - MAC Boom Tubes (2005 - 2009 GT) godspunk32 Parts For Sale 1 12/7/15 03:07 PM
Switching from a 2013GT to a 96-98 cobra trackpack13gt SN95 Mustang 6 10/2/15 09:20 PM
Battery Recommendations? PonyMuscletang13 2010-2014 Mustang 14 9/24/15 02:40 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010, The Mustang Source
